Old June 27th, 2020, 17:13
RavenMocker's Avatar
RavenMocker RavenMocker is offline
Fuse Panel Connector
Im still working on my 97+ dash, engine, AW4 conversion. I am looking for a the fuse box diagram for an 1998 XJ Limited. I have found tons of diagrams with the fuses and relays listed but non with the female to male connectors. Anyone know of a one that I can cut and paste for reference while installing the wiring harness?
Old June 27th, 2020, 17:28
RCP Phx RCP Phx is online now
Re: Fuse Panel Connector
Maybe a pic, I'm having a hard time understanding what your refering to? Are you even asking about the PDC or the interior panel?
Old June 27th, 2020, 17:40
im unable two load a photo? but let me look for a link
Old June 27th, 2020, 17:43
Its the fuse box on the passengers side. Im having issues loading a pic... but if you look at a diagram on the upper fuse box you will see C1, C2, C3... etc... Im trying to find out what plugs into each.
Old June 27th, 2020, 18:08
That's all in the FSM but it will take some work to put all that info together as it's on multiple pages.
Old June 27th, 2020, 18:17
ok.... I don't have an FSM but I did find one online. I feel like a dumb arse now.
Old June 27th, 2020, 18:21
Depending on what version/format you find, mine is section 8W-80 for what you are looking for.
Disconnect Fuse Block Connector in Engine Bay OkieXJ OEM Tech Discussion 7 February 2nd, 2019 10:15
FUSE BLOCK BULKHEAD CONNECTOR tugalo OEM Tech Discussion 1 September 20th, 2013 22:26
RENIX FUSE BLOCK BULKHEAD CONNECTOR tugalo OEM Tech Discussion 4 September 18th, 2013 11:36
Fuse Panel/Bulkhead Connector Gasket? RAVC1 OEM Tech Discussion 2 July 11th, 2011 19:46
getting rid of the fuse box bulkhead connector on a 89xj outlander Modified Tech Discussion 4 January 25th, 2010 10:13
