Old June 25th, 2020, 13:55
tjmotter's Avatar
tjmotter tjmotter is offline
Shout out to MMO
'90 XJ with 200,000 miles. Left some bad gas in it last year and while it was running fine, gas mileage dropped off a cliff so I pulled the plugs to find fouling on 3 cylinders. I did a leak down test on all the cylinders (cold) and had 25% leak down on 3 but 50% leak down on the other 3 with all the air coming out of the crankcase. My working theory was that the bad gas caused the top compression rings to stick.
Tried the "old school" approach and poured a couple of ounces of Marvel Mystery Oil into each cylinder and let it sit for a couple of days. Magically I am now back to 25% leak down (cold engine) on all cylinders. I suspect it will get better once I fire it up for a bit. Pretty good considering the miles on the old girl.
Old June 26th, 2020, 11:05
Saudade's Avatar
Saudade Saudade is offline
Re: Shout out to MMO
I use it in every oil change.
1988 Laredo 2wd Auto, AKA "Grey Ghost", 206K
Old June 27th, 2020, 05:32
AAubinoe AAubinoe is offline
Love that stuff, also splash a little in every small engine gas tank. Its a mystery how it works!
Also sea foam top engine spray! Most of the time when your dealing with old combustion engines its just gunk somewhere causing issues.
Shout out to BPB Demonoid369 NorthWest Chapter 2 November 23rd, 2014 20:12
Shout out yhateanxj? NorthWest Chapter 3 March 15th, 2014 13:27
Shout out from Dubuque IA ruffrich26 Midwest Chapter 6 October 25th, 2012 20:26
Shout out to all WickedOnE530 SoCal Chapter 2 June 19th, 2009 19:05
Shout out to XJensen WickedOnE530 Sierra Chapter 1 September 1st, 2008 18:12
