Old February 10th, 2020, 04:10
brap999 brap999 is offline
Gauge cluster issue
I recently picked up a '99 XJ. I'm trying to get it street legal and to pass the state inspection here. One of the issues that came up recently was that when I started the XJ and turn the head lights on the gauge cluster wasn't working, and the airbag light was on. If I turn the headlights off and then back on again everything starts working and the problem doesn't come back as long as it continues running. It seems to happen randomly and I can't consistently reproduce the problem.
One day when I was test driving it the gauge cluster was working, but the airbag light was going on and off randomly. I'm not sure if that's related or not. It doesn't happen that often.
I'm not sure where to start on this problem other than to try to throw another gauge cluster on it, but I have to wonder if there is a better fix. Thoughts?
Old February 10th, 2020, 05:15
BigNuge's Avatar
BigNuge BigNuge is offline
Gauge cluster issue
I have read that the cluster being wonky is a somewhat common issue with the later model XJís. In fact, when I was looking at one (a 2000 that I didnít buy because it was rotted to death) it had a cluster that came in and out during the test drive.
From what Iíve read it is a pretty simple fix involving removing the cluster and cleaning up contacts.
BigNuge's 99 XJ Build
Old February 10th, 2020, 05:40
RCP Phx RCP Phx is online now
Re: Gauge cluster issue
The air bag light may or may not have anything to do with the cluster issue. Usually the air bag light is related to the clock-spring failure but since they're both contained w/i the same column harness...........
Old February 10th, 2020, 07:46
xjnp242 xjnp242 is offline
My gauge cluster has gone bananas a few times in the 20 years since i've owned my xj.
Removing the cluster and making sure there's no bent, dirty or corroded connector pins has always fixed it. Basically just re-seating the cluster.
In your case you've got something going on with the headlights which is affecting the cluster.
Before diving in too deep, i'd check better yet remove and clean all the grounds to the engine, chassis and firewall.
Its also possible there's a flaky fuse or corroded fuse socket causing intermittent issues.
Old June 26th, 2020, 13:25
QuandAns42 QuandAns42 is offline
I keep my fire alarm batteries going by shaking them aggressively and cleaning the contacts when they start to beep... it works for a surprisingly long time. Unfortunately I didn't think to try that with my cluster. My understanding is that problems like these are usually degenerative, and that was certainly my situation. It started out occasional and eventually it just died entirely.
It's great you've been able to limp by for so long, but I would be worried about depending on that method long term. Since I got mine replaced, no issues whatsoever, so I can throw that suggestion into the hat. Got good help from these guys, https://www.instrumentclusterstore.c...t_clusters.htm
Old June 26th, 2020, 16:06
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
My "new" 98 just started doing this.
When the cluster goes out and the airbag light comes ON, slap the top of the dash with the heel of your hand. If the cluster instantly comes back ON, cleaning the contacts almost always solves the issue.
Originally Posted by bimmerjeeper
People are dumbfounded when I tell them I know how to change the spark plugs on a car.
Old July 4th, 2020, 02:12
Down under Down under is offline
There is the cluster check , keep finger on odometer when turning ignition on.
My contacts look great and clean. But I often have to tap the dash to get p
RPM and Speedo working..?? Illumination lights are spastic as wel
Old July 4th, 2020, 06:32
Tim_MN's Avatar
This test only checks the cluster gauge function and internal cluster circuits, it does not test the physical condition/cleanliness/continuity of the connections on the backside.
Old July 4th, 2020, 19:24
Oh, thanx Tim,
So if my tacho and Speedo need a tap to get going sometimes...
And contacts look very clean.
Internal issue?
Or poor contact terminal?
Is there a diagram of connectors that show the grounding pins? In case they are poor?
Old July 5th, 2020, 16:36
Tim_MN's Avatar
I don't think cleanliness can be judged by eye, if you have it apart, generously apply some plastic safe electrical contact cleaner.
Other Cherokee owners have had success by very gently twisting the male contacts a few degrees to increase the contact pressure in the female half of the plug assembly.
Strange, intermittent gauge cluster issue... JeepNoob OEM Tech Discussion 5 January 23rd, 2017 16:35
instrument gauge cluster issue? md21722 OEM Tech Discussion 6 October 18th, 2014 10:26
Volt gauge reading 18v on '91-'96 cluster +other gauge issues while off. J308 OEM Tech Discussion 5 March 12th, 2012 14:46
Change gauge cluster to full needle gauge cluster. QuillsXJ OEM Tech Discussion 2 February 7th, 2010 06:59
Gauge cluster/Dome lights issue bigalpha OEM Tech Discussion 30 September 27th, 2009 14:34
