Old April 14th, 2006, 10:17
87xjco's Avatar
87xjco 87xjco is offline
renix coil, which wire for tach
Hooking up an aftermarket tach. Anyone know which wire is negative side of coil?
1987 Cherokee with renix coil. Has 4 wires on the coil,
3 wires together in one plug
Yellow, green/white, black
Center plug is a two wire plug but only one wire in connector and it is yellow/white
Old April 14th, 2006, 10:33
tgoff's Avatar
tgoff tgoff is offline
Re: renix coil, which wire for tach
I have also installed an afermarket tach on my 86 2.5L and I believe they have the same coil. I think you coil looks like this one . If it does what i did was wrap the tach lead around the negative termainal of the prongs that you see sticking out. It holds itself in fine and thats what the autogauge instructions told me to do. I'm sure you will find out its nice having a tach.
Old April 14th, 2006, 10:53
kleake's Avatar
kleake kleake is offline
If I remember right, the coil was marked?? And,,,, it seems like it was the front most terminal when looking at the mount.... Don't quote me, but I think that is right....
Old April 14th, 2006, 11:16
87xjco's Avatar
Mine has a straight row of round terminals that hardshell connectors attach too.
I took the coil off and there are no markings. But there is one flat spade terminal above that row that was not attached. I bet that is where the factory tach's hooked up.
Anyone else know if that is correct?
Old April 14th, 2006, 12:19
87xjco's Avatar
Figured it out. It was the green/white wire which is the very end terminal.
trailer wiring (4-wire and 7-wire) oang Tow Rigs and Trailers 17 September 23rd, 2009 15:47
Automotive wire vs. regular wire montanaman OEM Tech Discussion 17 February 23rd, 2006 15:08
Tach Wire - 96 XJ MarkF Modified Tech Discussion 1 October 26th, 2004 09:03
Tach wire clean96XJ Modified Tech Discussion 0 September 6th, 2004 15:09
Installing aftermarket Tach, what wire? mark268 OEM Tech Discussion 2 December 30th, 2003 10:57
