Old August 14th, 2019, 10:54
Hubjeep Hubjeep is offline
P0705 (NSS), tried two new switches, one reverse light shuts off when braking
Howdy,
Been a long while since I posted on any forum, but got a problem with my 1999 238,000 mile XJ 4.0L.
While replacing the floor pans I replaced the NSS since I had to wiggle the shifter to start and to get reverse lights to come on sometimes.
Shortly after my check engine lights comes on with P0705, so I buy another new switch (also aftermarket) and the code comes back! I found the wiring diagram and checked continuity between the wires and they are good.
Weird thing... when in reverse both backup lights come on, but when I step on the brake the passenger side one shuts off!!! CEL means it fails NYS inspection.
Any ideas? Thanks!
-Hub
Old August 14th, 2019, 21:14
lawsoncl lawsoncl is offline
Re: P0705 (NSS), tried two new switches, one reverse light shuts off when braking
Check the grounds at the taillights. I bet you have a bad one on that side. Check the wiring harness connector for the tranny/NSS on the passenger side of the firewall.
Old August 15th, 2019, 09:23
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Hm. Another thing to check if the grounds don't solve it is the turn signal switch. I have an old 80s Dodge that at one point was doing some weird random stuff on the brake lights - sometimes no brake lights, sometimes the left only, sometimes the right only, sometimes normal. After a lot of poking around myself, I gave up and took it to someone; a new turn signal switch (the bit inside the column, not the lever you pull on), and it was back to normal.
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old August 15th, 2019, 17:36
blu3fan's Avatar
blu3fan blu3fan is online now
Its always the connector if you have cleaned the nss.. take it apart its probably rusty/broken inside.
Old August 20th, 2019, 09:30
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
Pull the kick panel on the passenger rear and check the main harness to sub harness connector for the tail light. A rust hole in the passenger rear wheel well caused water intrusion and corrosion at the non weather sealed connector and a P0705. I ended up bypassing the connector with crimp and seal connectors.
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Looking for automatic trans reverse light color to wire in the reverse lights Atm3535 OEM Tech Discussion 0 January 19th, 2016 04:25
P0705 issue, no reverse lights dirtyjerseyjeep OEM Tech Discussion 12 January 29th, 2013 17:13
Reverse braking thump SgtJCJ Modified Tech Discussion 17 April 8th, 2008 14:02
Clunk-Reverse/Braking Bowzer OEM Tech Discussion 5 December 1st, 2005 18:04
Braking in reverse ? Cherokee91Red OEM Tech Discussion 7 August 16th, 2004 08:51
