SoCal Chapter The SoCal Chapter covers Southern California and Arizona. Please post local topics here. |
Thread Tools | Rate Thread | Display Modes |
OBDII Reader?
Is there anyone local to Thousand Oaks that has a reader I can borrow to check and clear a check engine light on my 99 xj?
Had some small issues last weekend, long story so I wont tell it. TIA Aaron |
#2
Re: OBDII Reader?
Autozone, Kragens, Advance Auto, Checker Auto, they will all pull the codes for you for free.
#3
Re: OBDII Reader?
Good to know!
Thank you, Aaron |
#4
Re: OBDII Reader?
Re: OBDII Reader?
OK, I went to the Moorpark Autozone and they still let you use the reader. They just wont check it for you.
These are the codes that came up: P0705- Transmission range sensor circuit malfunction P1491- Manufacturer controlled auxilary emission control malfunction/ Secondary switch solenoid circuit malfunction I checked the codes, then erased them. I started the engine, drove around the parking lot, (used all gears, aw4 tranny) and got the light again. Rechecked and only one code returned. the P1491 code. Does anybody have any info on where I should start with troubleshooting or any more specific info on what the codes mean? This thread should probably be moved to the OEM tech forum but I dont know how to do that. Thank you guys for all the help! Aaron |
#6
Re: OBDII Reader?
Re: OBDII Reader?
You wouldn't happen to have a second gear switch of one of those new AWShifters do you?
Prior ![]() '89 Laredo • '96 Country • WFW WWU? Adopt-A-Trail keeps trails open - Have you volunteered this month? Quote:
#8
Re: OBDII Reader?
No, I dont, but I'm still searching for any more info on the codes. No one in OEM tech wants to touch this thread. So it looks like Im on my own.
Thanks for the help guys. Aaron |
#9
Re: OBDII Reader?
Thread Tools | |
Display Modes | Rate This Thread |
code OBDII OBD check engine | goodburbon | OEM Tech Discussion | 40 | December 24th, 2009 08:23 |
Code reader for 1990 XJ 4.0??? | bn6339 | OEM Tech Discussion | 4 | October 5th, 2004 22:44 |
Will an OBDII scanner work on a '96 XJ? | SimpleXJ | OEM Tech Discussion | 6 | January 23rd, 2004 00:12 |
ObdII codes | AZXJ | OEM Tech Discussion | 2 | July 22nd, 2003 05:27 |
