OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
Hello guys.I have a question regarding the 4 WD drive system.
I have a 1995 Cherokee with 4.0 H.O. and automatic. When I am driving down the road at any speed and I shift from 4 high to 2 high,the 4 WD does not release for about 300-400 ft of driving,sometimes more,and when it does release there is a loud clunk from the front axle. It always releases,but it used to do it nice and smoothly. There are no unusual noises while in 4 wd and it seems to work perfectly. Just a loud clunk,after shifting from 4 high to 2 high. Is there a vaccum shift motor that could be getting sluggish? Any ideas on the clunk?? I have owned this Jeep for 5 years and this is something new. |
#2
Re: 4 wheel drive release question??
XJguy |
#3
check the fluids?
have they been changed recently? |
#4
are your tire pressures equal and is tire wear even?
a slight offset in wheel rotation will cause enough bind to make 4wd difficult to shift in and out of. |
#5
I don't know it this is the 'proper method', but it's been working for me.
I had always had the bind issue despite even tire pressure, etc. Someone on here posted that they put the tranny in Neutral, then shifted into 2WD, then the tranny back to Drive -- has worked every time! I do this while going at about 10-20 mph. (also tried the forward/reverse method, but it doesn't always work as well. Besides, who wants to go backwards?) |
#6
That's the same thing I do too. Otherwise, mine doesn't alway's come out of 4wd. It's like the tranny keeps pressure on the transfer case and won't let it change. I have the NP242 transfer case if that matters.
#7
If you keep your foot on the accelerator so there is pressure on the splines in the transfer case, it CAN'T shift out of 4WD. After shifting the lever, you need to release the accelerator slightly for a moment to allow the shift to take place.
Also, the process works better with lubrication. Someone else already asked -- when's the last time you changed the fluid in the transfer case?
Eagle - Lifetime ![]() Owner/Driver/Enabler of "The Fleet" Self-appointed President-for-Life of the World MJ Preservation Society |
#8
Mine did the same thing...drained / filled with fresh juice and it got much better.
#9
Fresh fluid and let off the throttle when you shift between gears in transfercase should get you back to normal.
#10
I have the same issue with my 98. Would you all agree on the same solution. Check/change t-case fluid?
#12
in my 99, the 242 pulls the same stunt on me. it certainly helps to keep freshfluid and i try to hit the linkage with a shot of WD every so often. i also found that uneven, mismatched tires, or a slight difference in tire pressure will usually bind her up. i also shift from D to N while rolling, then try to put it 2wd. if that dosnt work i just stop, maybe roll back a little, and sometimes wait until she's good and ready to "pop" into 2wd. and well if that dosnt work, i just keep it in full time and treat it like im drivin a big subaru. trying to push four wheel powerslides and all.
Thread Tools | |
Display Modes | |
Buick 3800 in a rear wheel drive??? | daytripper | Tow Rigs and Trailers | 20 | March 14th, 2008 18:14 |
Wheel U-Joint | ken johnson | OEM Tech Discussion | 5 | December 6th, 2003 22:17 |
Headers Question | Garthbmn7 | Modified Tech Discussion | 1 | December 6th, 2003 06:40 |
The Georgia Bounty Runners Four Wheel Drive Club needs your help! | rbarton | Non-Tech / Off Topic | 0 | October 20th, 2003 09:04 |
4 wheel drive not engaging what broke? | IDXJ | Modified Tech Discussion | 8 | April 14th, 2003 20:42 |
