Old November 5th, 2003, 19:14
juicexj24 juicexj24 is offline
Blown Radio Fuse...Help
On Friday the radio was working fine, turned the thing off...started it back up no radio. Replaced fuse, burned it right out. Replaced it again later that night, burned right out again. I have checked the fuses on the amp that I have and they are fine. I would guess it's a ground wire but I have no idea where to start looking for it. Any help would be great. Juice
Old November 5th, 2003, 21:37
ChiXJeff's Avatar
ChiXJeff ChiXJeff is offline
Curmudgeon
Maybe not a ground wire, but a positive with a worn spot that is shorting to ground.
ChiXJeff
ChiXJeff
Lifetime member
"Jeeps are Cherokees. All other models are wannabes." Deb. K.
Old November 5th, 2003, 22:35
Eagle's Avatar
Eagle Eagle is offline
Lifetime NAXJA Member
In fact, definitely not a ground. A short is a wire that contacts ground when it's not supposed to. A ground wire is intended to contact ground, so who cares if it does it 6 feet or 6 inches after the device?
It's a bit of a PITA, but remove the radio and unplug it from the connector. Then replace the fuse and run a jumper with a test light from the power terminal in the connector to ground and see if that makes it blow.
Eagle - Lifetime Member
Owner/Driver/Enabler of "The Fleet"
Self-appointed President-for-Life of the World MJ Preservation Society
Old November 6th, 2003, 07:58
Thanks for advice, I'll try that first Eagle. Good Day, Juice
FS Rim and Radio cce4469 For Sale: Private Party Only. XJ ITEMS ONLY 1 December 9th, 2003 10:21
CB Radio XJWheelie Tow Rigs and Trailers 2 July 3rd, 2003 08:17
Power Window Fuse Drewlee77 OEM Tech Discussion 0 May 18th, 2003 15:07
Radio wiring issues, 96 XJ egon OEM Tech Discussion 6 April 6th, 2003 19:05
Blown 4.7L stroker? crytech Modified Tech Discussion 3 April 2nd, 2003 06:43
