OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
transfer case swapping - should I do it
Hi All,
My daughter rolled my '88 XJ I-6 Auto. I've purchased a '92 XJ I-6 Auto. They are both the Larado model. The '88 has a 'full-time' 4x4 transfer case, but the '92 has just 4x4 Hi and Lo. It doesn't snow much in San Diego where I live. My use is nearly all sand and dirt in the local deserts. I've not used the 'full-time' feature but preferred to put my '88 in regular 4x4 hi or lo, so I guess the '92 transfer case will fill my needs. I am considering swapping transfer cases from the wrecked '88 to the '92 Should I? Will they swap without major mounting issues? Thanks! |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
transfer case woes,.. | BILLXJ | Modified Tech Discussion | 15 | May 24th, 2005 15:25 |
Transfer case spline count info wanted. | lunghd | OEM Tech Discussion | 4 | May 2nd, 2005 19:54 |
transfer case cracks, | BILLXJ | Modified Tech Discussion | 8 | June 30th, 2003 00:10 |
transfer case inspection guide,.. | BILLXJ | Modified Tech Discussion | 4 | May 10th, 2003 07:53 |
..NP 231 transfer case studs,.. | BILLXJ | Modified Tech Discussion | 4 | May 8th, 2003 13:06 |
