Old August 25th, 2004, 23:01
canuckxj canuckxj is offline
Post Axle swap D35 to D44 - ABS
I'm looking to swap the rear 35 with a D44. I have a 01 limited with ABS. Can I simply disable the system by removing the relay and fuses? Do I need to change the booster or master cylinder?
Thanks
Old November 3rd, 2004, 14:57
mhead mhead is offline
Re: Axle swap D35 to D44 - ABS
I have a '92 XJ 4.0 auto tran with a D35 in back. I have (had) ABS although I'm not sure which manufacturer. Had some troubles with the ABS (it kept coming on unexpectedly for no reason) so I just unplugged the two electrical connectors leading to the controller. Been this way for most of the year. I left the hydraulic connections alone. Haven't had any problems except the 'check abs' light stays on.
I've put a D44 in the back so I guess my abs is gone for good. Something to be glad about...
Old November 5th, 2004, 10:09
MarkF MarkF is offline
When I swapped in my D44 into my 96, I removed the rear ABS sensor wires, pulled the relays from under the rear bench seat and there was a fuse in the fuse panel under the dash that will shut off the ABS dash light.
I did not do anything else to the pump or MC and it works fine.
Of course then I added 32" tires and 1000lbs of armor and now they aren't so fine anymore. I'm now working on swapping in disc brakes on to the D44.
Good luck.
Mark F
Old November 5th, 2004, 12:55
XJ_ranger's Avatar
XJ_ranger XJ_ranger is offline
Talking Re: Axle swap D35 to D44 - ABS
if you disable the ABS by way of pulling fuses - then that kills the front too. Any way to keep ABS in front and swap a D44 and not have ABS rear?
Old November 5th, 2004, 22:44
jrsxj98's Avatar
jrsxj98 jrsxj98 is offline
DILIGAF
Nope they work as a unit. if you diasble one you do both.
I just did this swap. I just pulled the wires from the connection under the back seat and pulled the relay under the hood. everything is fine.
27 to 29 spline axle swap balloo93 Modified Tech Discussion 16 September 2nd, 2004 12:03
Front axle swap candidates to replace the Dana 30... TB-XJ Modified Tech Discussion 1 May 5th, 2004 19:03
Regear or swap axle? BrianJr OEM Tech Discussion 3 November 20th, 2003 13:17
D44 axle question BLUTO Modified Tech Discussion 21 October 17th, 2003 00:22
Rear axle swap candidates CW Modified Tech Discussion 8 August 9th, 2003 17:14
