Old October 29th, 2019, 15:08
Rainman's Avatar
Rainman Rainman is offline
power steering morning sickness.
so in winter im getting the hard to steer of a bit, first thing in the morning.
its gotten worse every winter for the last 3 winters.
i have read that lucas power steering fluid can help. so that will prolly be the first step.
What i want to know is could i expect a rebuild kit to solve the problem? cause apparently it can be caused by wear on the seals the seals AND the casing wall.
any body got any first hand experience?
Old October 30th, 2019, 09:32
lawsoncl lawsoncl is online now
Re: power steering morning sickness.
Mine has been stiff and really noisy on cold morning ever since I replaced the pump with a Cardone reman. It's okay once it warms up though. One of these days, I'm going to replace the pump again. I might try a fluid flush with synthetic and see if that helps first.
Old October 30th, 2019, 09:39
RCP Phx RCP Phx is offline
Unfortunately those symptons describe the spool valve in the steering box.
Old October 30th, 2019, 14:05
I replaced both the pump and the steering box at the same time. The noise sounds like a straining or bad pump though.
Old October 30th, 2019, 14:09
MickeyS MickeyS is offline
were the pump and box new or remanned?
I replaced my stock pump which was leaking with a brand new PSC pump; it's louder and audible because it's more powerful.
I replaced my stock rack with a remanned one from lares and it has been nothing but problems, super stiff in the cold, absolute dogshit. I want to pull it and warranty it but it's a pain in the ass to do because it's so heavy and I'm pretty slight so I've just been dealing with it. once it warms up its a little better but the box sucks
Old October 30th, 2019, 14:54
Both pump and steering box were remanf Cardone. The sound is the same noise that you get with the steering wheel cranked hard over against the stops. That sucks if it's the box, because it's a bigger job to get in/out.
Old November 1st, 2019, 05:19
denverd1 denverd1 is offline
Its not too bad. Pull the airbox and it's all accessible. I'm on my third lol
Old November 1st, 2019, 06:19
cruiser54's Avatar
cruiser54 cruiser54 is offline
ever change the fluid?
Old November 1st, 2019, 09:43
lazyxj's Avatar
lazyxj lazyxj is online now
NAXJA Member #1310
Can't say I have ever received a Cardone pump or steering box that was worth the effort to install. Tried two rebuilt steering boxes that were as bad as the one being replaced.Same story with the pumps.
One of the best purchases for the Jeep was the PSC big-bore steering box and pump, installed years and tens of thousands of miles ago. It's still like new.
To help the steering last, install an inline filter in the return line.
https://www.amazon.com/gp/product/B0...G33AHCDXS2YFVA
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Elevation sickness Jeeperrick Non-Tech / Off Topic 11 September 1st, 2009 14:44
I have come down with a sickness.... 88manche NorthWest Chapter 16 August 8th, 2008 19:12
Its a sickness... macgyvr Midwest Chapter 15 July 24th, 2008 06:44
House 'O Heeps...... Definitely a sickness.... YELLAHEEP Colorado Chapter 47 January 28th, 2008 00:22
AM sickness biscuitboy87 OEM Tech Discussion 10 September 25th, 2004 10:02
