Old October 26th, 2019, 07:07
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
Battery Temperature Sensor
I have a 2001 XJ and inside the battery tray is a battery temp sensor. Well, I busted that tray when I rolled the Jeep, so I went to the junkyard and got a different tray out of a 1996 or older model that doesn't have that sensor. Now, when I start the truck and run it, I get a code 1492 and the engine light stays on.
Is there a way to bypass that sensor, or do I just need to go back to the yard and grab either a new sensor or a new tray? I cut the wires on the old sensor and threw it out, not realizing that it would cause engine codes.
Dirk DeYoung--Member #176
You'll never leave Harlan alive.
1996 ZJ (200GRND)...2001 XJ (TRALRIG)...2006 XK (TOW RIG)
Old October 26th, 2019, 07:19
RCP Phx RCP Phx is offline
Re: Battery Temperature Sensor
Best solution would be to re-install the sensor, you could build a emulator circuit but that's going to require knowing how the circuit works.
Old October 26th, 2019, 08:51
lawsoncl lawsoncl is offline
The engine computer will reduce the charging current if it thinks the battery is getting hot, so you might have reduced charging right now. Ideally, you should replace the sensor. I think it's a standard NTC type thermistor just like the coolant temp sensor, so substituting a 10-kohm resistor should trick the computer into thinking the battery is around room temperature.
Old October 26th, 2019, 10:07
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
The sensors are not expensive, about $20 from Rock Auto for a NTK and $40 for a Mopar sensor.
https://www.rockauto.com/en/moreinfo.php?pk=10052452
https://www.rockauto.com/en/moreinfo...373666&jsn=427
Napa has them too.
https://www.napaonline.com/en/search...Qualified=true
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old October 27th, 2019, 09:23
techno1154's Avatar
techno1154 techno1154 is offline
My 1996 XJ have one. The previous 1994 did not.
Best to get it replaced. Trying to trick it will not work. The PCM is expecting to see the values change as the engine runs. I tried to substitute the sensor with a resister and the PCM returned an error indicating it did not see a change in value. You could change the tray to one with the hole or you could just drop the sensor somewhere near the battery.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old October 27th, 2019, 18:58
Cottontail's Avatar
Three-De Off-Road
I picked up a sensor at the junkyard today for $2.00. I drilled a hole in the tray that I bought the other week and it is reading find and the engine light is off.
XJ 1997 4.0 Battery temperature sensor marts. OEM Tech Discussion 1 April 11th, 2017 14:45
Battery Temperature Sensor jmulz824 OEM Tech Discussion 4 December 3rd, 2011 18:06
Temperature sensor? jfiscus OEM Tech Discussion 9 April 19th, 2007 11:50
coolant temperature sensor? arkansasduck OEM Tech Discussion 4 September 24th, 2006 03:15
Temperature Sensor reson46 OEM Tech Discussion 7 April 28th, 2003 07:58
