Old October 23rd, 2019, 07:45
BayStYat BayStYat is offline
The dreaded clunk in front in thread. Sorry!
So I have a clunk when going over bumps at about 10 miles an hour. I also have the same clunk noise in four-wheel-drive taking off from a dead stop.Iíve checked around the front end the shocks, ball joints control arms etc.
I live on A rock road and it makes the worst noise on those fast uneven bumps. When Iím driving on the concrete I donít hear it at all.
When I wiggle the U joint it definitely makes a tapping sound but it seems like the tap is coming from the shaft not the u joint.
The noise seems to follow the shock up-and-down movement. If the shock is moving fast up and down I hear And feel the noise. If Iím on the highway and things are relatively smooth I donít hear it at all
here is a video
https://youtu.be/zGfwUsFWNj4
Old October 23rd, 2019, 10:39
90XJ_Seth's Avatar
90XJ_Seth 90XJ_Seth is offline
Re: The dreaded clunk in front in thread. Sorry!
I had a massive clunk when shifting from reverse to forward and vice versa. It was the U-joints on the rear drive shaft.
Side note: Also check your engine mounts, when my engine mounts were worn out my exhaust was hitting the crossmember. New mounts, no clunk there.
Old October 23rd, 2019, 14:08
Re: The dreaded clunk in front end thread. Sorry!
thanks, just checked motor mounts and they are good. upper and lower control arms are good, shocks and spring tight, ball joints seem fine. steering seems tight.
i plan to pull the axels this evening
Old October 23rd, 2019, 18:35
tjmotter's Avatar
tjmotter tjmotter is offline
My brothers '93 XJ had a nasty thunking noise that was intermittent. Turned out that the ring gear in the diff had cracked
Old October 23rd, 2019, 18:52
8Mud's Avatar
8Mud 8Mud is offline
The easy way to check U-joints is to jack up the front and jam a big screwdriver through the yoke so it jams, turn the tire a little and watch the rubber seal around the U-joint cap for movement. A ring of rust dust around the cap seal is also a tipoff.
While you have it up in the air use a fulcrum and a pry bar to pry up on the knuckle and watch the top ball joint.
A good flashlight helps in seeing the movement if there is any.
Old October 24th, 2019, 04:49
i am afraid it may be in my axle.
Old October 24th, 2019, 04:51
thank you sir, i will try that today and report back.
Old October 24th, 2019, 04:52
What are the parts in an axle that could be worn or broken that could cause a clunking noise?
Old October 24th, 2019, 05:44
ok, so let me try and explain what i found.
I grabbed the U Joint at the front axle that attaches to the TC. I turned it side to side and found play in the passenger side axle
So when the u joint is turned side to side by hand, i have a half inch play side to side with a clunk, but the axle does not turn. It seems to only clunking against the passenger side axle.
As if the axle is missing a spline and there is a gap before if grabs
I hope this made sense.
Should i pull the diff cover and look?
Old October 25th, 2019, 06:55
ok, so i think i found it. *The wheel hub assembly has some excessive play in it. In theory it makes sense because i hear/feel it when i hit fast bumps and in 4wd take off from a stop. *I also looks to be original at 164K miles. *
I will change and report back. thanks everyone*
Old October 31st, 2019, 19:05
so it was not the wheel hub. $%^%$#
ok so new development. I put the truck in reverse and let it move on it own i tap the brake and i hear and feel a clunk in the brake pedal it self. also the fire wall. let off and repeat i get the same results. I also hear and feel the clunk when going slow over light bumps.
I pulled on the upper control arms and could not get any movement, could they still be the issue ?
Old October 31st, 2019, 19:40
RCP Phx RCP Phx is offline
Yes, same for the lowers if they are not torqued to at least minimum they will cause that noise, same appies to the trackbar.
Old October 31st, 2019, 20:19
My dear sir,
I have been chasing this god forsaken clunk for weeks. I have changed the wheel hubs, new complete V8 Grand Cherokee steering components, all new sway bar bushings, checked brakes, steering etc.
the dude i purchased the truck from put new aftermarket lower control arms on.
i read your post walked strait to the garage and was able to just turn the bolts with me hand.
I toured them down and guess what!
NO MORE &^%&^^@(*^&(*@&$)*$ CLUNK
you sir are my hero.
I will sleep better now!
Old October 31st, 2019, 22:53
MickeyS MickeyS is offline
congrats! always good to see threads resolved.
Old November 1st, 2019, 07:42
Now go check everything else since you haven't owned the vehicle for very long!
Dreaded front end clunk bassboost OEM Tech Discussion 0 November 12th, 2013 15:05
Clunk in front end relyt OEM Tech Discussion 3 September 26th, 2010 13:12
front end clunk/pop xjJeeper95 Modified Tech Discussion 3 April 1st, 2008 22:45
Clunk in front end, only when wet. cem Modified Tech Discussion 3 December 19th, 2005 11:16
Front End Clunk 98XJSport Modified Tech Discussion 7 December 14th, 2005 04:30
