Old October 23rd, 2019, 18:25
cruiser54's Avatar
cruiser54 cruiser54 is offline
Re: TPS ohm issue, renix 1990 i6 automatic.
Well, that's good news, and a great idea on your part.
Old October 23rd, 2019, 19:26
90XJ_Seth's Avatar
90XJ_Seth 90XJ_Seth is offline
Now on to why my exhaust smells like crap. Thinking my newish CAT is blown. Last year I was pumping rich so much I was clogging it and getting black smoke...
Old October 23rd, 2019, 19:42
cruiser54's Avatar
Literally smells like crap?
Or smells rich and burns your eyes?
Old October 23rd, 2019, 20:21
90XJ_Seth's Avatar
Smells super rich and is really strong, when I turn off the engine smells like strong burnt fuel. I thinks its the O2 sensor again. I keep burning these things out. But I think it blew out the cat because there was a time where it actually started causing my jeep to stall out and send black smoke out from right under the passenger side where the CAT is..
Old October 23rd, 2019, 20:33
cruiser54's Avatar
A bad cat won't cause it to smell rich. Mine with NO cats don't smell rich.
Keep in mind the MAP sensor uses the same ground as the TPS. MAP is the most influential sensor that affects richness. How's the tube MAP to throttle body? How's it's ground?
I have a fix for the MAP hose.
Old October 23rd, 2019, 20:48
90XJ_Seth's Avatar
I don't know how to TAP a hole in the TB but that's a brilliant fix. I used gray permatex to seal the hard line hose to the TB connection. I then used a rubber vacuum line for the MAP to the hard line hose and sealed the rubber vacuum line to the hard line with gray permatex too. I verified there's no goop inside. Should I run a better ground for the MAP sensor then too?
Old October 23rd, 2019, 20:51
90XJ_Seth's Avatar
I did not seal the connection to the TB just the hard line to the rubber boots that go into the TB.
Old October 23rd, 2019, 20:52
cruiser54's Avatar
I'm very concerned there is an issue with that line.
At idle, spray some carb cleaner all around it slowly. If the cleaner hits a vacuum leak, you'll know!!
Test the ohms reading on the ground wire at the MAP for fun. And yes, you could ground each and every one of those sensors on that ground circuit separately.
Old October 23rd, 2019, 20:53
90XJ_Seth's Avatar
That grounding definitely sucks for sure. I will find some carb cleaner to check. Now to learn how to tap a screw hole...
Old October 23rd, 2019, 20:54
cruiser54's Avatar
If the rubber plug got clogged with goop, the MAP sensor thinks the engine vacuum is low and tells the ECU that the engine is under a load, and the ECU holds the injectors open longer....makes for a rich mixture.
90XJ_Seth's Avatar
Report back tomorrow if I can. Thanks!
Old October 23rd, 2019, 20:55
90XJ_Seth's Avatar
That I did not know.
cruiser54's Avatar
Easy. Go slow. Probably a youtube video on it.
Old October 23rd, 2019, 21:25
90XJ_Seth's Avatar
Just checked the MAP ground. 2.4 OHMS, Grounded to the chassis ground right 3 inches from it at .5 OHMS. Sprayed electronic cleaner at the MAP hose because I didn't have CARB cleaner. Made no difference. But I am suspect of that still.
Old October 23rd, 2019, 21:29
cruiser54's Avatar
This is called progress. Check ohms at the CTS, IAT...
Imagine if every sensor in the circuit was giving an inaccurate reading due to bad grounds.......
1990 charging issue xjtrailrider OEM Tech Discussion 2 July 19th, 2015 19:39
1990 XJ headlight issue. tchase OEM Tech Discussion 2 January 12th, 2015 13:33
1990 RENIX 5 speed swap with 1998 HO Automatic Monster3663 Modified Tech Discussion 12 August 17th, 2013 20:46
1990 Jeep Cherokee 4.0, Automatic 264k miles - $1200 OBO X-Earth05 MWC For Sale/Wanted Forum 2 August 19th, 2012 09:29
