Old October 13th, 2019, 13:26
Fishfinder Fishfinder is offline
Key stuck in ignition
I have a 94 XJ. The ignition lock cylinder will not rotate all the way back and release the key. The steering wheel will not lock when turned off. Any ideas, Solutions?
Old October 13th, 2019, 14:45
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Key stuck in ignition
A light tap on the key with a screwdriver handle while you turn often works.
People are dumbfounded when I tell them I know how to change the spark plugs on a car.
Old October 13th, 2019, 15:13
RCP Phx RCP Phx is offline
Is the steering wheel cranked hard one way? Try turning the steering wheel and the key at the same time.
Old October 13th, 2019, 19:33
blu3fan's Avatar
blu3fan blu3fan is offline
yes what pcp said.
Lean on the steering wheel left/right and slowly turn the key.
it should come out.
I would not recommend using hammers around keycylinders. spray pbblaster/wd40 down there and gently lean on it
Old October 14th, 2019, 17:54
GamblySmurf GamblySmurf is offline
This happened to me. Give it a firm whack with something.
Old October 14th, 2019, 19:39
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Mine does this now and again, just give it's some thuds with your plan and it should move normally. Maybe you'll need something harder to give a sharper hit, but it shouldn't take too much.
You haven't mentioned the steering wheel being locked so I assume this isn't related to that scenario.
Old October 24th, 2019, 21:38
The steering wheel will not lock. Tapping on it we're smacking it with a screwdriver or the palm of my hand does not seem to work.
Old October 25th, 2019, 07:25
scottmcneal's Avatar
scottmcneal scottmcneal is offline
The 97 Club
Sounds silly, but have you move the shiftier in & out of park? It has a cable that could be in a bind
Smiley face added so people won't feel but t hurt.
Don't make old people mad.We don't like being old in the first place, so it doesn't take much to piss us off.
RIP Shady, the Greatest Father & man i will ever know.
Old October 26th, 2019, 08:05
The 97 Club
did you get the key out?
Old October 26th, 2019, 20:36
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
And if you did, replace the lock ASAP before it strands you in the middle of nowhere. Don't ask how I know.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old October 28th, 2019, 08:02
Dragonslayer Dragonslayer is offline
Had this on my '96 a few years ago. In my case, I couldn't turn off the engine!
The ignition lock pushrod that activates the ignition switch (near the lower base of the
top of the steering column) was the culprit.
Remove the steering column cowl, and (maybe) the instrument gauge pack. You'll see
part of the rod on top of the steering column, disappearing deep into the dash.
Be sure that nothing is interfering or fouling the rod. Then spray it liberally with silicone
lube (let the lube dribble down the rod, onto the ignition switch) while jiggling it with a
pair of needle nosed pliers, and also try working the ignition key On & Off a few times
until everything works its way loose.
Ignition getting stuck Khary23 OEM Tech Discussion 4 December 2nd, 2010 19:31
Key stuck in ignition LegoRacer OEM Tech Discussion 4 February 26th, 2010 12:10
My ignition key is stuck! flingshot Colorado Chapter 10 December 4th, 2009 22:44
key is STUCK in the ignition!! and im out in moab!! natethegr8t OEM Tech Discussion 17 April 30th, 2009 01:54
Ignition Key Stuck Jester99 OEM Tech Discussion 5 January 6th, 2009 15:13
