This is not a "bad bulb" case.
My left blinker has been doing the strobe blink intermittently for a while, I found that if I pull down hard on the lever it blinks at a normal rate. Ok fine, buy a new combo switch.
Plugged in the new one and tried it, same issue although pulling it down hard doesn't slow the blinking.
Ok fine, there's a short to ground somewhere, removed all bulbs front and rear on L/S and when pulled to left turn position the flasher buzzes but doesn't click.
Ok fine, short to ground somewhere it is but here's the screwy part, after letting it buzz in the L/T position then returned to center position the RIGHT rear t/s light goes into strobe blink.
Anyone ever see this ?
Does the harness for the right side go up over the roof and down to the left side main harness or is it run under somewhere ?
