Do you use sleeves with BPE's??
Fred85
Orange, VA
Never really thought about this, but when using BPE's do you need to put a metal sleeve in the bushing or does the BPE bolt make direct contact with the rubber shock bushing???
Just trying to make sure i have everything in order when i go to put the lift on....
i think you may want the sleeve to prevent crushing the rubber bushing(like a crush sleeve).... i could be wrong... that said, i use 5/8" bolts for my rear shocks, and had to take out the sleeves; i may try to drill out the rubber and put bigger sleeves in if it mutilates my bushings
Not typically!
^that is helpful, thank you........you know the bolt size as well?
i'm doing the angle iron and bolt method for BPE's :D
x2 cheapest way!
