Old August 10th, 2018, 14:26
brielly brielly is offline
AX15 seal orientation
Replacing the seals on my ax15. In the middle of doing front retainer bearing seal, I got distracted and forgot which way the seal goes in. I think it goes flat side down like in the photo but can anyone confirm? Thanks!
Old August 10th, 2018, 14:27
Re: AX15 seal orientation
https://drive.google.com/open?id=1Os...bXS1XsDA2j7ESq
D44 Pinion Seal Orientation comanche91 Modified Tech Discussion 8 February 24th, 2011 10:24
Changing front bearing retainer seal on AX15 XJNASH OEM Tech Discussion 2 May 23rd, 2006 20:25
Rear seal R&R on the AX15 Kejtar OEM Tech Discussion 1 September 5th, 2003 14:48
Help me understand the seal on the AX15! Kejtar OEM Tech Discussion 5 September 4th, 2003 12:34
