Old August 6th, 2018, 11:35
alexgalexg's Avatar
alexgalexg alexgalexg is offline
Over my head in problems and need help
Ok so took a trip to the shop today. That bunch of codes was because the dude didnt plug the reader in correctly. Here is what I had the shop check.
Wiring
Compression
Upstream o2
All data from obd II
They are as baffled as I am as to why it pings without premium and has had 2 cracked heads in 2 years 25,000 miles. They said it's running perfectly. They did notice the compression was a hair high (in the attached photo) but that is likely due to the new head in December. And the numbers are not high enough to really be causing any issues.
They also said even if the timing jumped a tooth it would be running like crap.
Any other tips? Really worried about this thing blowing a head in the winter... dont have a garage
Old August 6th, 2018, 12:15
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
Re: Over my head in problems and need help
Only thing I can think of is there is excess carbon build up on the pistons.
The only other option is either the block or the head was decked too much and a shim or thicker head gasket is required.
Just spit balling.
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Old August 6th, 2018, 12:55
alexgalexg's Avatar
Just spit balling.
Pistons are very clean. Checked on that in December. What little carbon there was I used seafoam and scrubbed off
Old August 6th, 2018, 14:21
RCP Phx RCP Phx is offline
Those numbers may be on the "higher" end, but by no means "high".
Old August 6th, 2018, 14:23
alexgalexg's Avatar
I'd check the timing chain so see if maybe it's just a bit loose (maybe a quarter of a tooth off) but that's so much work for possibly nothing wrong I really dont intend to do so.
Old August 6th, 2018, 17:08
trippled trippled is offline
Agreed. I just checked a 04 4.0. all 160-155.
Have you checked the actual ignition timing with a timing light versus the PCM desired timing (scan tool)? If for some reason it's too advanced it can ping.
Old August 6th, 2018, 17:19
alexgalexg's Avatar
I unfortunately do not have access to this tool. I would be interested in trying to save this engine since most of it was replaced in December of this past year
Old August 9th, 2018, 14:40
alexgalexg's Avatar
Sits around 10-12 at idle and I cant see what marks it goes up to when you rev it up but it goes to the same spot and stays there
Old August 9th, 2018, 16:17
alexgalexg's Avatar
I forgot to mention I'm talking about timing in the last one. Used a timing light
Old August 10th, 2018, 18:04
alexgalexg's Avatar
I couldn't compare the timing from the timing light to the timing on front the computer because my live feed on my reader is too slow to really tell me if they are matching. I was hoping someone here would tell me if these are good numbers
Old August 12th, 2018, 11:01
CJR CJR is offline
Re: Cracked Heads
Many years ago I went through cracked heads on a four banger. I was informed by a number of engine shops that it was a chronic problem with this brand of vehicle. I pulled the cracked head and checked it out on my bench. I concluded the ports in the head were undersized on purpose to reduce the flow and run hotter so as to improve emissions. The reduced flow through the head allowed carbon to build-up in the ports. As carbon built-up in the ports, the head started to run hotter and eventually the head would crack. My solution was to mildly port the head to improve flow. Problem solved and I never cracked another head in about 250,000 miles.
Pinging/pre-ignition can also be caused by carbon build-up in the head's combustion chamber. The fact that there is a carbon build-up in a particular part of the combustion chamber indicates a " flow dead-zone", i.e. poor flow through the combustion chamber. A mild porting improves flow during the valve overlap duration (i.e. when both intake and exhaust valves are open).
Hope this helps.
Best regards,
CJR
Old August 12th, 2018, 18:59
alexgalexg's Avatar
Originally Posted by CJR View Post
Re: Cracked Heads
Hope this helps.
Best regards,
CJR
That is an interesting experiance. I was sure to get an 0630 head do I don't think the flow is restricted but it's definitely something to keep in mind.
Thank you
Old August 13th, 2018, 16:32
alexgalexg's Avatar
What do you guys think about seafoam in the crank case. My top end and pistons are clean but I know the previous owner did not change the oil often. When I put a new head on originally the valve train was covered in thick sludge. So maybe buildup in the crank case is the issue
Old August 13th, 2018, 17:25
What plugs are you using? As in exactly what part number is on the plugs?
Old August 13th, 2018, 19:11
alexgalexg's Avatar
I will have to get back to you on the part number. But they are the standard ngk copper plugs. Everyone says that's what the 4.0 runs best on so that's what I use
New XJ, New Problems (Head Gasket) Xj_idget OEM Tech Discussion 10 September 3rd, 2012 19:52
Head problems 01 XJ dirtyjerz5.0 OEM Tech Discussion 1 July 22nd, 2010 06:49
Head light problems (HELP) canadianwheeler OEM Tech Discussion 1 July 16th, 2007 22:29
head problems? montysbxj OEM Tech Discussion 0 October 18th, 2005 18:02
Head on - Still have BIG Problems! GSequoia OEM Tech Discussion 15 August 13th, 2003 14:11
