Old August 10th, 2018, 18:26
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
Re: Project Unicorn - a light duty trail rig
Every man knows you can't win without Currie.
I can't win WITH Currie... They sold my a nice shiney very expensive paperweight and have been ducking my emails about the issue, but that's neither here nor there.
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231, with a few basic bolt ons.
Click here to support
Old August 13th, 2018, 09:07
cracker's Avatar
cracker cracker is offline
oh man, that sounds terrible. I thought Currie was the best company ever....When I get a JL and do a crappy build like Cal's, I was going to bolt on Currie axles.
cal: I would happily have run these 37's on my Dana 30
Bryan C: Cracker is right, I am a dick. Cracker is an a-hole. So that must make Sequoia our taint.
MoparManiac: Rockclimber, I feel like every post you make on here is a regurgitation of the latest Pirate4x4 thread.
DirtboundOffroad always takes great care of me
Old August 13th, 2018, 21:21
rockclimber's Avatar
rockclimber rockclimber is offline
Associate
They probably know you're friends with the crackerbater and have blacklisted you by association .!..!.
[cal]You're an idiot rockclimber.
[StinkyFab]RockClimber is a tool.
Old August 24th, 2018, 10:36
cherokeecrawler's Avatar
cherokeecrawler cherokeecrawler is offline
It's been a little bit, how's the build coming along?
Old August 24th, 2018, 10:38
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
gathering parts for the front end now. trying not to go broke buying everything at once.
Old August 24th, 2018, 10:47
Ahh, I understand the struggle. When do you think you'd work on it? I love the build. Lots of things i want for my XJ now...
Old August 24th, 2018, 10:50
cal's Avatar
cal cal is offline
Little bits all the time. I'll be working on the housing this weekend, but I don't know that I'll be posting up pictures until I get to a good checkpoint, so to say.
Old August 31st, 2018, 15:47
Ronbo's Avatar
Ronbo Ronbo is offline
Production parts for aFe intake are in stock now. First ones off the line are already installed in my car.
Didn't even need to take a photo. Just hotlinking to their webpage. Probably should have washed under hood of my car before I let them take it.
https://afepower.com/afe-power-54-46...-intake-system
Bummer, although it's probably only a matter of time before it's certified;
"This intake system is not CARB exempt at this time and is not legal for sale in California or use on vehicles registered with the California Department of Motor Vehicles."
25/32 ton XJ.
Old August 31st, 2018, 16:20
cal's Avatar
cal cal is offline
The EO is currently sitting on an engineers desk at CARB waiting to be stamped.
Any day now.
Old September 4th, 2018, 08:56
cal's Avatar
cal cal is offline
Spent a little time polishing the turd over the weekend. Plan is to center the coils over the tube, run the trackbar to the axle side inner C like 4643's axle, and run some more robust bracketry. Since I'm going that far, I may as well rotate the knuckles for proper caster and pinion angle.
If you look at a dana 30, the coils are forward of the inner C and slightly outboarded, causing them to rub the C's. So I'm going to outboard the C a quarter inch on each side to help with that, while I'm at it.
Cut all the brackets except UCA off and ground the housing clean. UCA bracket will get replaced but left it there until I have a replacement to help me locate the new one.
Ground the welds off of the inner C's.
If you haven't done this before, you grind until you can just see the line where the C ends and the tube begins. Its a lot more material off than you'd expect.
Once I have that all the way around, a couple hits with the hammer and the C is moving.
After measuring Dallas's MJ (which has the same lift height as my XJ) I need ~8.5* pinion angle, and am shooting for 6* caster at ride height.
I ordered up Tera's inside sleeve kit for the XJ/TJ 30. 2" .250 tube that they cut .030" off on the lathe to make it easier to install.
I didn't take pictures of it, but I welded a 1.5" washer to the end of a chunk of 3/4" tube and spent a half hour scraping all the crap out of the inside of the axle tube. A shocking amount of dirt came out..
Drilled about 8 3/8" holes in the housing for plug welds.
Tube went in this far by hand.
Tube went in this far swinging one handed with a rubber mallet.
Another couple hits two handed got it to here.
From there it only moved 1/2" or so at a time but kept moving and went in without an issue.
Now to fill the plug welds, weld the knuckle, and drink a beer.
Dallas decided we need the .035 wire for this job (knuckles). Not often he upsizes.
I didn't manage to get the other side done, I only had a few hours to spend in the shop, so I'll get the other end done next week and drop it off to be geared and wait for the condescending comments from Avery about how I should't waste my time when its not a 14 bolt.
Old September 4th, 2018, 09:14
cracker's Avatar
So all the weight of a dana 60 with the strength of a dana 30?
Old September 4th, 2018, 09:20
cal's Avatar
cal cal is offline
I'm not sure that adding 9.5 pounds counts as the weight of a dana 60.
Old September 4th, 2018, 10:41
freerider15's Avatar
freerider15 freerider15 is offline
Out boarding the C's a 1/4"?
How are you controlling axle shaft rotation axis in relation to the ball joints?
XJ Buggy On Tons
Old September 4th, 2018, 10:47
cal's Avatar
cal cal is offline
That's not changing?
Old September 4th, 2018, 11:09
Coffee Drinker
Are you planning to run 1/4" less spline engagement in the carrier or are you getting custom length shafts?
New Project 89 XJ Unicorn zachxj01 North Atlantic Chapter 9 May 26th, 2016 17:39
Anyone use OME LIGHT DUTY leafs? djlarroc Modified Tech Discussion 19 August 10th, 2013 19:39
Project:Unicorn SAMSET Midwest Chapter 27 September 28th, 2012 11:58
WTB light duty truck tires XJwheelman NAC Classifieds 0 June 5th, 2011 15:41
Some light duty mods for a camping XJ terryd Modified Tech Discussion 10 January 11th, 2008 17:50
