Old January 2nd, 2018, 15:09
RCP Phx RCP Phx is online now
Copper/brass heater coil?
Does anybody make one for a 2000? I can't find any signs of a leak, but I can smell the anti-freeze!
Old January 3rd, 2018, 09:48
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: Copper/brass heater coil?
Rock Auto has three choices.
http://www.rockauto.com/en/catalog/j...ater+core,6864
Quality unknown.
Both the heater cores and evaporators are stock in both my 01 and 97.
Someday i'm to have to face the music and replace them.
If you are going to replace the heater core, it might be a good time to change the A/C evaporator, while the dash is opened up.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger. stroker, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old January 3rd, 2018, 10:02
Quality unknown.
With all of them being aluminum!
Old January 4th, 2018, 18:00
ehall's Avatar
ehall ehall is offline
I bought an APDI/PRO when I replaced the heater core in my 91. It showed as copper on rockauto but was aluminum in the box. I needed to install it so I did, been working fine.
my '91 beater rebuild
Old January 5th, 2018, 09:29
md21722 md21722 is offline
You could copper/brass heater cores in early 2016 but by late 2017 when I looked again it I only saw aluminum. Comparing the current offerings the biggest difference seemed to be if they came with the anti-rattle foam wrapped around them or not.
Copper/brass heater core for less than $400? Ben824 OEM Tech Discussion 7 October 18th, 2016 18:30
Copper heater pipe broke! Help! Borgli OEM Tech Discussion 10 March 14th, 2014 15:56
alum vs brass/copper rad - update fuzzydog Modified Tech Discussion 3 June 30th, 2007 01:22
copper heater lines - info fuzzydog Modified Tech Discussion 0 June 19th, 2007 08:52
Heater Core Leak AC-Inop Remove Evap Coil? wilcharl OEM Tech Discussion 1 March 13th, 2007 10:54
