Old January 12th, 2020, 13:03
WalmartGardner WalmartGardner is offline
Engine running hot in cold weather, not over heating
Hey guys,
I have been a fan of the forums for years. Thank you so much for the information over the years. I have just registered my first account because I haven't been able to figure this out myself and would really appreciate some help.
I have found some similar threads to the title of this one, but never found a resolution in them - or the threads died.
My 97 XJ sport (bought January 2019, 95k miles) is getting warm even though the ambient temperature is fairly cool here in NC.
When warming it up in the morning, no matter how long I leave it, the temp gauge never surpasses 210F. When driving, it's a slightly (width of the temp needle) below 210F. But when I'm sat at a traffic light, or in a parking lot, after 3 to 5 minutes, the temperature reported raises to halfway to the next temperature tick above 210 (220?). At this point, the electric fans turns on, and lowers the temperature to 210, and then the electric fan turns off. Then the behaviour repeats. The temperature then raises halfway to the next tick again, electric fan on, temp lowers, electric fan off.
So far I have replaced the thermostat and the thermocouple.
I can't spin the mechanical fan all the way around - it goes maybe an 8th of a rotation. So I figure the fan clutch is working.
I'm at a loss because it only happens after driving it, and not when warning it up from cold.
I would love some input from you guys.
Thank you!
Old January 12th, 2020, 15:09
Re: Engine running hot in cold weather, not over heating
As an added note, this started happening roughly one week ago. Previously it would not get above 210 in temperature, even in the 100F weather we get in NC. I am concerned because this is happening in winter.
Old January 12th, 2020, 17:50
MickeyS MickeyS is offline
an xj will warm up to 218, kicking the fans on, if it idles long enough. just several minutes is possible, even in cold weather. they are designed to run at 210 while driving in any temperature. the e fan helps idle without overheating. I have overhauled my entire cooling system replacing everything with stock components and using a mishimoto aluminum radiator. it functions just like your say yours does, and will get to 218 at extended idle. I think your vehicle is operating normally.
Old January 12th, 2020, 18:53
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
I disagree, this in not normal, you should be concerned. The e-fan is doing its job, but in cooler weather, the engine temps should not rise above 210*. Overheating at idle, or in your case an unusual temperature rise, very strongly suggests a faulty mechanical fan clutch.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old January 12th, 2020, 19:00
maybe. op said car is not overheating. if the vehicle is sitting in the same place sucking in air from the hot engine bay, it's not going to stay at 210. I think maybe 3-5 minutes is a little short, so clutch could be a bit weak or there could be a small blockage somewhere. but I have flushed my xj, replaced radiator, water pump, hoses, it will tick up if it's sitting still for a while.
Old January 12th, 2020, 20:09
RCP Phx RCP Phx is offline
Another vote for a faulty fan clutch.
Old January 12th, 2020, 20:13
Black1990jeep Black1990jeep is offline
I can turn my fan by hand, it dont stop at 1/8 th turn.
Old January 13th, 2020, 08:25
I agree that it is picky to be concerned about it when it's not overheating, it's just that I haven't had this behaviour from this xj before. Even in the >100F weather we get in the summer time. This is my road queen, but I will be taking her to the 4x4 beaches over summer and want to make sure she's in tip top shape. Thank you for your input.
@Tim_MN, thank you. I'll do the fan clutch this week. Based on everything I've read, I thought it might be that, but the fact that it didn't spin freely changed my mind. Thank you!
I'll definitely post my results after replacing the fan clutch this week.
Old January 15th, 2020, 16:51
Update
Fan clutch did the trick! I replaced it with a CarQuest xj fan clutch rather than the ZJ clutch. Performance is good.
I have a feeling with it being CarQuest, it may need replacing again soon lol
Engine running cold CJ96xj OEM Tech Discussion 4 November 28th, 2010 14:35
Engine Running Too Cold 160F jeepsrock OEM Tech Discussion 29 December 23rd, 2006 14:07
cold outside = better running engine?!? mikeny59 Modified Tech Discussion 8 October 15th, 2006 20:31
Cold Starting problems, and running rough when engine is cold Culinary_Hooligan OEM Tech Discussion 0 December 8th, 2005 02:52
Engine running cold MarcoXJ Modified Tech Discussion 1 November 28th, 2004 09:39
