Old January 10th, 2020, 20:30
Black1990jeep Black1990jeep is offline
exhaust back pressure transducer, 1990 XJ
My Exhaust back pressure transducer melted do to a clogged catalytic converter. I need a replacement for smog test, but cant find this part. Will someone please direct me to where to get one? This is for a 1990 XJ 4.0 liter inline six. This is the plastic body valve that acts as a switch for the egr vacuum based on exhaust pressure. I also need the rubber elbow that connects the transducer to the exhaust.
I dont even know what part number to search for.
Thanks
Old January 11th, 2020, 07:25
old_man's Avatar
old_man old_man is offline
Re: exhaust back pressure transducer, 1990 XJ
Normally that is part of the EGR.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old January 11th, 2020, 08:22
Saudade's Avatar
Saudade Saudade is offline
https://www.napaonline.com/en/p/CRB226422#
1988 Laredo 2wd Auto, AKA "Grey Ghost", 206K
Old January 11th, 2020, 09:41
Thanks, that looks like it! My egr is however fine, only the plastic transducer melted.
I did find a simular looking transducer on Amazon however, actually two of them with different part numbers...
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
and
These are Standard Motor Products part numbers G28012 and G28014
I am not sure if these are the same as what I had, or their differences. But these are a lot cheaper than buying them with the egr valve.
Does anyone know about these two linked transducers?
I got smog test coming up soon, and will need to replace the melted transducer and the now gutted cat, the cat clogged 500 miles from home,so I gutted it out to get home.
thanks
Old January 11th, 2020, 16:40
Saudade's Avatar
They look close. However Amazon says they don't fit my '88, as always YMMV.
I don't like throwing money at my '88 to pass smog but spread over 2 years and knowing I'm good to drive works for me. CARB cats are not cheap. I just replaced my Bosch O2 with an NTK as I gear up for my smog in a few months.
Anyway, forgive my rambling. If you have time, try one of the transducers. Let us know if it passes.
1990, transducer diaphragm has a hole in it, where can I get one? xjtrailrider OEM Tech Discussion 4 February 26th, 2010 21:07
egr transducer troubleshooting big black xj OEM Tech Discussion 1 July 8th, 2008 16:10
Fuel pressure problem 1990 4.0L MoFo OEM Tech Discussion 9 January 12th, 2004 11:12
Low oil pressure warning system and oil pressure back up Q's Bones Modified Tech Discussion 7 June 19th, 2003 20:31
