Old January 8th, 2020, 21:09
Black1990jeep Black1990jeep is offline
Help broken down in Death Valley
1990 stock renix Little power. Canít rev in neutral past 3000 rpm. Stuck at furnace creek now. Almost no power on highway. Can barely climb grades at 15 mph on highway. Temp goes up when going up hill and must pull over after every few miles. Temp cools in five minutes if I rev motor. But then goes up again to redlinein a few miles again. On level road canít maintain 25 mph. Yesterday found the egr transducer melted this has the rubber elbow off an exhaust tube to influence egr operation. That elbow was melted. I have plugged the egr tubes so no vacuum leak now nor exhaust leak either. Yet still almost no power. Canít rev above 3000 rpm even when in neutral. Suspect rich running by smell. Any advice? I am 500 miles from home. Cap and rotor look ok. Does NOT seem to miss. But Idle is very low and will die once a while when in neutral.
Old January 8th, 2020, 21:41
Runnin'OnEmpty's Avatar
Runnin'OnEmpty Runnin'OnEmpty is offline
Re: Help broken down in Death Valley
I think you have a clogged catalytic converter.
Maybe you can remove the tailpipe and punch
it out enough to get back home....
Old January 8th, 2020, 21:57
Does anyone know where to find a vacuum gage so I can test for restricted exhaust. Any shops or auto stores near furnace creek? I’d hate to cut up the exhaust to find it was fine. Down stream side is welded to the muffler. Once I cut it if I an then jam committed to a hole in the exhaust. Don’t want to make this worse. Would the exhaust leak from the egr transducer port be enough to cause the oxygen sensor to make me run rich enough to kill the at? That port is about 1/16 inch inside diameter. I might have dendritic that way for 500 miles. I did try shorting the fuel pump Ballester resistor but she still wont rev this time last 3600 rpm. But engine is colder now okay be that is why she an rev a bit more thanacouple hours ago when last tested. Can’t do anymore engine tests tonight as I am in a camp ground.
Old January 8th, 2020, 21:59
Oops. Autocorrect was wrong. Should read...... driven that way. Rather than..... dendetric.
Old January 8th, 2020, 23:33
Would a clogged cat cause enough back pressure to blow off the egr exhaust back pressure transducer rubber elbow? I wonder if that is why mine blew me off followed by the transducer itself melting from the hot exhaust flowing out the transducer ports blown of rubber elbow.
Old January 9th, 2020, 02:18
jeep ride's Avatar
jeep ride jeep ride is offline
When my cat convert got plugged it would glow red hot I punched holes in it so I could drive it home
Old January 9th, 2020, 04:45
Iris Not glowing red but can broken bits still be blocking flow enough to cause lack of power?
Old January 9th, 2020, 09:33
old_man's Avatar
old_man old_man is offline
Absolutely. If the CAT is bolted on instead of welded, just unbolt it. If not, take a hacksaw and cut the exhaust pipe before the CAT. If that is not it, you can fix it for a $5 slip on joint from Autozone.
Tom Houston - Former Colorado Chapter Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old January 9th, 2020, 09:43
THank You All. Cat is now cleaned out. Runs like a top now. Two broken bolts removing it but we had spares. Trip is saved. Thanks!
Old January 9th, 2020, 12:19
Anak's Avatar
Anak Anak is offline
Stranger
Great to hear.
Baby it's cold outside.
Old January 9th, 2020, 20:47
Absolutely great to hear.
It's scary when you're 500 miles from home and
your horse goes lame.
Old January 9th, 2020, 22:43
jeep ride's Avatar
Good news
Ah Que Dicha - Death Valley/Panamint Valley 2015 Bryan C. Sierra Chapter 39 February 22nd, 2016 14:00
Death Valley/Panamint valley Late DEC trip? twinhauler Sierra Chapter 13 November 17th, 2015 12:46
Panamint Valley and Death Valley Photos Letterman Adventure Forum 31 April 30th, 2011 18:57
Death Valley.... Original_MudButt SoCal Chapter 20 January 29th, 2010 10:00
Death Valley ??? DaJudge Adventure Forum 11 August 9th, 2007 16:36
