Old January 8th, 2020, 06:00
xactorocker xactorocker is offline
Question Blower motor only coming out defrost
Hey, I recently bought a 1992 xj and i was able to get the blower motor running the connector had melted. but now the air only comes out of the defrost vents. I have heard it is a vacuum hose that controls this anyone know what hose it is? thanks
Old January 8th, 2020, 07:44
ehall's Avatar
ehall ehall is offline
Re: Blower motor only coming out defrost
All of the vents are activated by vacuum diaphragms. There is a little vacuum manifold on the rear of the HVAC control unit that routes engine vacuum to selected appropriate diaphragms. The defrost vents are normally open and closed by vacuum.
If you have weak vacuum from the engine or if there is a problem with the vacuum routing in the cab, you will only get defrost.
Most common issue is the vacuum reservoir ball behind the bumper is broken or removed.
my '91 beater rebuild
Old January 8th, 2020, 09:49
ok thank you I will try these when I get home later and see if it fixes it.
Old January 8th, 2020, 10:29
Question Re: Blower motor only coming out defrost
also, could it come from any vacuum line that is missing or broken or does it need to be one connected to the air system?
Old January 8th, 2020, 15:29
old_man's Avatar
old_man old_man is offline
Virtually any vacuum line can cause it.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old January 9th, 2020, 17:08
dang ok found a few messed up lines now I gotta try and find out where they go to. thanks
Blower motor HaleYes OEM Tech Discussion 1 June 26th, 2009 15:28
Blower Motor KennyH-96XJ-87MJ OEM Tech Discussion 1 November 1st, 2008 13:02
Blower motor not working. replaced motor and resistor...Searched can you help? 99xjclassic OEM Tech Discussion 12 May 4th, 2007 21:31
Defrost blower only. Checked for vacuum leak, etc.. still need help. Redsnake OEM Tech Discussion 9 October 26th, 2006 13:45
Replaced my blower motor now i only get defrost!!! canadianwheeler OEM Tech Discussion 1 March 9th, 2006 18:01
