Old January 6th, 2020, 18:58
TylerA23 TylerA23 is offline
Any suggestions on rotors, calipers, etc after disc conversion
Im looking to do the disc conversion on my 98 xj with a Dana 35 here soon.
just planning a head and thought Id ask if there were any preferences or suggestion on which brand or stores to go with on the rotors, calipers, and pads. Prices seem pretty cheat on rock auto and amazon versus autozone etc. Just thought Id ask for person thoughts or suggestion on certain parts / stores
ill be getting the backing plates, prop valve, and caliper (core) from the junk yard.
thanks as always
Old January 6th, 2020, 23:20
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: Any suggestions on rotors, calipers, etc after disc conversion
I have had good experiences with the full Power Stop kits from Rock Auto.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old January 7th, 2020, 06:01
RCP Phx RCP Phx is offline
EBC yellow truck pads hands down!
Old January 7th, 2020, 07:20
ehall's Avatar
ehall ehall is offline
I had good experience with the pads from Black Magic Brakes, and he's a jeep guy so good to support him
Rotors and calipers I prefer the Centric Premium, but harder to find them. BMB has them sometimes too.
my '91 beater rebuild
Old January 8th, 2020, 10:42
blu3fan's Avatar
blu3fan blu3fan is offline
so. I hate to be the stick in the mud... but drums are fine.... u don't really need disks. the gains are minimal at most... money better spent elsewhere in my opinion.
sorry just my 2cents here.
I thought about this myself years ago and some people on this forum talked me out of the idea. glad they did.
Old January 8th, 2020, 11:27
lazyxj's Avatar
NAXJA Member #1310
I have to agree that rear discs do not provide much more powerful brakes and that the stock brakes can be made to work fine.
The biggest difference is not having to adjust the shoes and maybe a little more resistance to water.
Too much rear brake can cause rear wheel lockup in wet conditions. The Grand Cherokees equipped with rear discs have 4-channel ABS, to prevent lockup, a feature that cannot be transferred to XJs.
I would love to reactivate my 1997's ABS but with a 8.25 axle installed, no one has found a way to do this.
If you want to see a big difference in braking power, spend your money on upgrading to larger brakes with a WJ or Vanco conversion.
Under hard braking, most of a vehicle's weight is transferred to the front end brakes, the rear brakes do much less braking, bigger front brakes is where the real benefits are.
Old January 8th, 2020, 12:00
techno1154's Avatar
techno1154 techno1154 is offline
This tread is 100% accurate, and so it the one above it. I too have disks in the rear and see no improvement in stopping distance over drums that was on the 8.25 I replaced. Well,...there is just one advantage,...one do not have to continually get under the XJ and adjust the rear brakes. There is nothing wrong wit going disks in the rear. Just do not expect to see any improvement over a good working set of drum breaks.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old January 8th, 2020, 12:34
Vince's Avatar
Vince Vince is offline
There is an advantage for disc brakes on a 'C-clip' axle if you are unfortunate enough to break an axle shaft. Depending on the shaft damage they could enable a slow limp home or at least off the trail.
Old January 8th, 2020, 19:07
ehall's Avatar
I notice the improved performance of discs, not having to adjust is quite noticeable on long trips where drums start to fade. Discs react better to mud too, self-cleaning and easier to clean with a hose than drums that full up with mud
Old January 9th, 2020, 04:04
SlowXj SlowXj is offline
Besides mud, cleaning, etc, another way disks are Superior is on long stops. Think interstate off ramp. Better heat dissipation keeps brake fade down. This is where I saw improvement in my setup.
Old January 9th, 2020, 08:19
75SV1 75SV1 is offline
'I would love to reactivate my 1997's ABS but with a 8.25 axle installed, no one has found a way to do this.'
It has been done with the Ford 8.8. I think the guys sig was Jordach88 or Jordan88.
Old January 9th, 2020, 12:09
ehall's Avatar
Talyn did an ABS project on his 8.25, basically machined some ZJ rings so they could press fit over the 8.25 shafts without rubbing the tubes.
Supposedly an 8.8 can be done by machining off every other tooth on the differential tone ring. Something like that might work with the KJ 8.25 housing too (don't know).
XJ D44 can be done by swapping in shafts and parts from the ZJ aluminum D44 housing.
Old January 9th, 2020, 12:30
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
This is what I run, though I'm on an 8.8
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old January 9th, 2020, 14:26
Soapy1 Soapy1 is offline
I am thinking of doing the Terraflex rear disc conversion and upgrading the rear axle says at the same time.
Old January 11th, 2020, 03:25
Rainman's Avatar
Rainman Rainman is offline
i did a zj on to a 8.25. drums suck from a maintenance perspective.
Best pads and rotors for d30 and ZJ rear disc conversion dan1977p Modified Tech Discussion 13 March 28th, 2016 13:30
14 bolt disc brake conversion brake lines (or anyone using k20 front calipers) blondejoncherokee Sierra Chapter For Sale 0 August 19th, 2014 10:56
Sticking Calipers on Teraflex disc conversion kit? JeremyW Modified Tech Discussion 2 July 14th, 2011 20:29
ford 8.8 disc brake rear 4.10 ratio complete except calipers and rotors joe88xj For Sale: Private Party Only. XJ ITEMS ONLY 3 November 1st, 2006 13:44
