Old January 14th, 2020, 08:37
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
Re: How can I hook up an efan timer on a 2001?
Originally Posted by Heavyopp View Post
I’ve had the manual switch mod for a year now — took apart and rewired the PDC so I could use an empty relay and fuse port — wired the new relay as described
I’m unclear how you incorporated a timer into this circuit — a wiring diagram would be helpful
I wired my switch hot at all times — I have to sit in a parking lot for 3 minutes to manually shut off the fan — would be nice to have the timer
The timer is wired in line on the wire from the switch that activates the relay- basically just clipped the wire and put the timer in the middle of it.
The timer has 12v power coming from the accessory fuse block I added, which is always hot, so it gets power whether the jeep is on or off.
I'll see what I can do on a wiring diagram. Again no hosting option that I'm aware of and I've never used taptalk either.
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old January 14th, 2020, 17:53
Heavyopp Heavyopp is offline
You are a paid, red letter member — you can host your photos right here on naxja
User CP — Albums — download your pictures to your album and then you can use them in your post
Old January 14th, 2020, 19:27
Timer with wiring. Yellow is the trigger wire from the switch, red is 12v power, black is ground. The red wrapping around the unit goes to the com terminal on the output side. Note the 4 on the display for the 4 minute setting.
Timer tucked down next to my ARB Compressor
Not sure why it rotated my switch photo but here it is:
John V.
RRC VP
Old January 14th, 2020, 19:28
Thanks for the tip. I knew this had been discussed but never heard it had been implemented.
John V.
RRC VP
Old January 15th, 2020, 10:13
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
I mounted the timer inside the middle console, after unscrewing and lifting the inner storage box out. A button to turn on the three minutes is located next to the TC lever.
Under the hood, a fused 40-amp relay drives the fan motor.
It's been eleven years since it was installed and while has never failed, I don't have wiring schematic . I do remember needing to use a diode or two to isolate the timer from the stock fan wiring.
https://www.flickr.com/photos/lwade/...th/3482846101/
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old January 15th, 2020, 12:43
Wiring diagram from the post I followed, with the timer wiring added in:
John V.
RRC VP
Old January 15th, 2020, 12:46
I know. I've read your posts on the subject multiple times over the years and I've got an ELK timer sitting in the garage. The ELK timer didn't do what I wanted. This one did.
John V.
RRC VP
Old January 15th, 2020, 16:44
lazyxj's Avatar
NAXJA Member #1310
Glad you got a timer to work, it is the only sure cure for hot soak issue.
I had problems with the ELK back feeding the fan circuit and ended up isolating the ELK with a couple of diodes. The ELK itself has been trouble free.
Old January 15th, 2020, 17:09
ehall's Avatar
ehall ehall is offline
Use a temperature switch in-line with the timer (or on the control side of the relay). Then it will only have power when the coolant is hot.
my '91 beater rebuild
Old January 16th, 2020, 20:10
https://youtu.be/89XjtV1n2zU
Video of the timer in action. I am clearly not a videographer
John V.
RRC VP
Aux Efan drama!! tommyboy Modified Tech Discussion 12 March 4th, 2009 18:59
WTB: 10 blade efan 1998xj1985 SoCal For Sale 6 August 2nd, 2008 20:51
97 manual efan switch?? gixer Modified Tech Discussion 9 May 5th, 2008 20:32
first timer texasxj TEST Forum 1 December 2nd, 2004 06:56
xj oem tow hook brackets with support braces and hook also oem gas tank skid for sale joe88xj For Sale: Private Party Only. XJ ITEMS ONLY 8 August 9th, 2003 15:41
