Old January 11th, 2020, 05:26
SlowXj SlowXj is offline
Any suggestions on rotors, calipers, etc after disc conversion
Isn't that kit like 600 bones? I swapped my complete 8.8 in for less than that....
$200 axle
$100 brackets
$100 soft brake lines instead of bending hard lines (because I'm lazy)
$50 u joint adapter
Reused rotors and new pads for cheap at Az. ..
Just throwing that idea out there.
Old January 12th, 2020, 09:45
Borgli Borgli is offline
Re: Any suggestions on rotors, calipers, etc after disc conversion
I went with EBC rotors and pads on all four wheels when I put in a Ford 8.8. They are amazing.
I originally had plans to go with a wj big brake setup, but that's been de-prioritized after getting the ebc.
Old January 12th, 2020, 12:27
Driver86 Driver86 is offline
I have DBA ceramic pads and T3 4000 series rotors front and rear ordered from Summit Racing for my XJ with rear ZJ disks. These are great performing brakes but they are pricey.
Best pads and rotors for d30 and ZJ rear disc conversion dan1977p Modified Tech Discussion 13 March 28th, 2016 14:30
14 bolt disc brake conversion brake lines (or anyone using k20 front calipers) blondejoncherokee Sierra Chapter For Sale 0 August 19th, 2014 11:56
Sticking Calipers on Teraflex disc conversion kit? JeremyW Modified Tech Discussion 2 July 14th, 2011 21:29
ford 8.8 disc brake rear 4.10 ratio complete except calipers and rotors joe88xj For Sale: Private Party Only. XJ ITEMS ONLY 3 November 1st, 2006 14:44
