Turn Signal Flasher Location
Dakine14
TN
I have a 2000 XJ Classic 2wd and i need to replace the turn signal flasher. The only problem with that is i can't find the thing. so if anyone could point me in the right direction that would be great. i know about the relays under the hood and the fuse block in the passenger side kick panel but everything i've found online listed that it was not on that fuse block. anyway any help would be great. thanks. :dunno:
It is under the driver's side of the dash. You need to remove the panel under the steering column to get to it. It's usually a white box up and to your left after you remove that panel. If you can get your signals to work at all turn them on so you can hear the clicking.
