95cherjustin
- doylestown, pa
Just got a scanner and code reader and was just checking all my sensors how can i check that all my sensor readings are good???
-tps is .08 to 3.8 volts at WOT
-02 sensor never stays the same it runs from lean to rich as i drive and never stays in one place
-map sensor is 1.5 at idle and sticks pretty low which means i have pretty good vacuum prob becuase all vacuum lines and fuel vapor canister is removed.
-coolant sensor seems to match degree's of coolant temp so thats good.
Anything else I need to check and make sure is good.
I got this because i was getting a injector code but it was getting heat soak from header and going into vapor lock # 3 injector, now its fine since it has radiant barrier on it.
