Old July 28th, 2020, 17:43
denverd1 denverd1 is offline
Best battery clamps w accessory studs
What are you guys using for connecting cables to the battery along with an ever growing list of accessories?
Just have winch and a few light harnesses, but it seems like I'm already out of room.
I'm using off the shelf shitty clamps. The real pisser is the cables are always corroding or somehow loosening themselves. I swear I take them apart and and clean everything and retighten at least every 6 months.
Whats the fix?
Old July 28th, 2020, 18:17
Evan03 Evan03 is online now
Re: Best battery clamps w accessory studs
What I'm running.
Winch and headlight harness is hooked to it.
https://www.autozone.com/batteries-s...nal/374187_0_0
Old July 28th, 2020, 19:30
Anak's Avatar
Anak Anak is offline
Stranger
Originally Posted by Evan03 View Post
What I'm running.
No thank you.
BTDT.
Scope Creep came with one of those. Junk. They are a cheap alloy and they collect moisture in the recesses for the grub screws which then works its way down into the wires.
Here is the solution: https://naxja.org/forum/showthread.php?t=1108471
Get solid lead military terminals and cover boots to go along with them. Lots of potential for adding on with ring terminals and lugs.
ETA: I just put The Varmints to work doing this very thing to the ZJ I recently picked up: https://naxja.org/forum/showthread.php?t=1159228
Old July 28th, 2020, 20:02
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
I bought the fastronics mil specs off Amazon
https://www.amazon.com/gp/product/B0...d-b31d6b1bfbee
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old July 28th, 2020, 20:59
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
military terminals are great, i run those plus a + busbar.
Old July 29th, 2020, 06:40
75SV1 75SV1 is offline
I've used these types:
https://www.grainger.com/product/25K...!1102900019466!
There are other makers. A NAPA by me carries them. They also come with dual 'ports'. ??
I use one of the cheap Import compressors. They do work with a bit of use. I've made 2-3 battery cable harnesses. The MEGA fuse is in my plans, too.
https://marinehowto.com/making-your-own-battery-cables/
Old July 29th, 2020, 07:07
old_man's Avatar
old_man old_man is offline
For the corrosion, use the treated felt washers you can get at any parts store. I also use DeOx on the connectors before assembly and then use the spray can of the terminal cleaner that coats with a reddish film when dry.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old July 29th, 2020, 07:29
Rockwood Rockwood is offline
Same here. Excellent connectors and have worked perfectly through a couple of batteries.
Don't forget like I did that the negative terminal is smaller than the positive. Took me a bit wondering WTF was going on...
Old July 29th, 2020, 07:52
old_man's Avatar
PartsExpress.com is a good supplier with tons of options. They also have great distribution boxes and fuse setups.
Old July 29th, 2020, 09:07
Felt washers: treated with what?
how do those silly things work anyway?
Old July 29th, 2020, 10:03
anybody soldering connections?
bought the amazon mil-spec kit. Thx John.
Old July 29th, 2020, 10:10
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
I soldered copper welding wire lugs to the bare cable ends.
Originally Posted by bimmerjeeper
People are dumbfounded when I tell them I know how to change the spark plugs on a car.
Old July 29th, 2020, 10:16
RCP Phx RCP Phx is offline
You should if you have the ability to do it right and also use good heat shrink.
Old July 29th, 2020, 11:29
I've done it both ways. I do shrink wrap over the wire and the connector. I didn't like welding cable as I remember it. I think the best was the boat wire or marine grade. It was tin coated before hand.
Old July 29th, 2020, 11:47
I bought new cables from mean lemons a couple years back so I didn't need to do any of that.
John V.
RRC VP
5.3 la accessory brackets Alexfowler Modified Tech Discussion 3 January 27th, 2019 13:23
battery cable clamps/now it won't start? N8N_99xj OEM Tech Discussion 22 June 17th, 2012 12:19
Spring clamps\worm clamps 88 Wagonman OEM Tech Discussion 38 July 22nd, 2009 12:47
BAttery clamps troubles T3hk1w1 Modified Tech Discussion 11 April 17th, 2008 15:42
