Old July 25th, 2020, 10:39
AndyEBR AndyEBR is offline
1987 jeep Cherokee ac, what is this valve in the suction tube
I'm reassembling my ac system after having some hoses rebuilt and putting in a 134a compatible compressor.
What is this valve in the suction tube? The hose is the low pressure side of the evaporator going into the top of the receiver/dryer. It's the coupler that makes the connection possible, but shy does it have a valve in it? Can I just remove the valve portion?
Sent from my SM-N975U1 using Tapatalk
Old July 26th, 2020, 19:41
AJPulley AJPulley is offline
Re: 1987 jeep Cherokee ac, what is this valve in the suction tube
It looks like a check valve. Ironically, I also have an '87 that I have to have all new hoses made. I do not recall that being part of the original hose. The expansion valve is the only metering device that is necessary that I am aware of. Most systems' liquid and vapor sides of the compressor equalize after the system is off, so I can't think of any reason.
Old July 28th, 2020, 09:39
It does, and I agree, typically they equal out when it's not running so I don't know what the point is... I was thinking I would just remove it but It is also the way the union joint seals... For some reason they didn't just use an o ring on the connection. Maybe it's an over pressure release valve too...
Jeep Cherokee A/C suction and discharge valves??? simspace OEM Tech Discussion 8 November 29th, 2015 16:22
1987 Jeep Cherokee keith_b00ne SoCal For Sale 8 October 16th, 2011 22:11
1987 Jeep Cherokee keith_b00ne Arizona For Sale/Wanted 7 October 16th, 2011 22:07
1987 Jeep Cherokee MNXJ39 MWC For Sale/Wanted Forum 6 July 22nd, 2010 17:44
1987 Jeep Cherokee 4x4 joebalsamo12 South East Chapter 11 August 27th, 2006 15:13
