Old June 14th, 2020, 18:58
ShoeterMcgav's Avatar
ShoeterMcgav ShoeterMcgav is offline
Re: JK 44s and other Fun Stuff
I dig it too!
97’ XJ lift lockers 35s mid arms 9"/hp30 trussed warn hubs wj brakes 1ton OTK 4.56s etc work in progress..
93zj BEAST 35s Claytons LAs 44/hp30 lockers bumpers headers etc $old
Old June 14th, 2020, 20:59
Evan03 Evan03 is offline
Pretty dang cool.
Watch that bot next to the coil. I did similar and its rubbing the coil.
Old June 14th, 2020, 21:07
I think he has been done with the swap for a while... Just slowly putting the build up page together with pics and what not
Old June 15th, 2020, 12:17
whitexj98 whitexj98 is offline
For steering I wanted to keep TREs. Offset GM 1 ton tie rod and drag link is GM 1 ton high angle. Track bar is 5/8" heims on both ends. Wide Open Design 7075 1.5" aluminum.
Ruffstuff axle side track bar bracket.
Figured a steering brace would be a good idea as well, so I got the Boostwerks. I wanted to keep my antirock so I also ordered the drop brackets. After mocking it up I didn't like how low the antirock was. So I cut it up and made it much better.
Much better, arms don't clear but I will fix that later.
Arms were not going to work, I made a bender setup for my press but the arms were still not long enough after bends so I ordered up longer ones from Currie.
Cycled the suspension a lot, its a tight fit but clears everything.
Also matched the rear with new Bilstein 5160s. Listed for a TJ but work all the same. With the correct shocks I was also able to setup the limit straps and build new correctly setup (full bump) stops.
Made some simple coil retention features.
And a little baby Bilstein steering stabilizer. This pic is also at full bump checking clearance, I cycled this axle so many times...
Old June 15th, 2020, 20:42
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
XJ44s lol xj.... man this thing looks fun. Nice welds btw, I hope I can weld that clean one day. ive never seen those knuckles before, but then again ive never followed jk stuff.
looking forward to whats next, let the good times roll!
Old June 16th, 2020, 05:37
JeffW JeffW is offline
What did you use for the rear e-brake cables? Can't seem to find any info on making that work with the JK axle.
Old June 16th, 2020, 06:00
I previously had ZJ rear disks on my 8.25, I was able to reuse those cables from that swap.
Old June 16th, 2020, 08:04
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
Awesome build.
This was the way I was planning to go until the TJ Rubi44/8.8 fell in my lap for a price I couldn't say no to.
Still kind of wish I had resisted to get wider axles and better brakes.
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old June 16th, 2020, 08:25
sdspearo's Avatar
sdspearo sdspearo is offline
Originally Posted by whitexj98 View Post
....also at full bump checking clearance, I cycled this axle so many times...
Ain't that the truth! I just relocated my TB and PSC ram using the same Ruffstuff TB bracket and wish I had an air assisted jack or something.
I like how you incorporated the sway bar into the steering brace, pretty trick. Boostwerks you listening?
'96 XJ: Locked up D44's on 35" Milestar Patagonia's, ChroMo axles, 6" lift w/ 3 link front, 4 link rear, AX15, Atlas 5.0, Internal cage, DIY beadlocks, hydro assist, big ass stinger!, ...
Old June 16th, 2020, 20:09
Are you keeping the Front radius arm setup on the new axle? If so... why?
Old June 16th, 2020, 21:01
GordoSmasho's Avatar
GordoSmasho GordoSmasho is offline
How are you getting away with the coils centered on the axle. I did that and had to cut them off and get offset mounts to make it work. Although i reused all the control arm mounts. They worked fine for me.
Old June 17th, 2020, 04:26
Yeah keeping the radius arms, been running this TNT kit for ~8 years now. It has crossed my mind to go to maybe a 4 link like the SFR kit but I really don't have any issues with this setup.
Old June 17th, 2020, 04:39
Why couldn't you make them work? I'm not sure where my wheelbase is at but I did move my track bar mount forward to give the coils more room to sit straight over the axle.
Old June 17th, 2020, 05:06
Tires were mounted up over the build, tedious process. 35x12.50R17 BFG KM3s on Method Beadlock 105s.
Old June 17th, 2020, 06:58
My front is pushed forward about an inch and a half but still used the stock tbar location. That’s probably how you achieved it. My coils bowed pretty good. I would hav had to push it forward like 4-5” more to get them to not bow. I did one run and decided i needed to redo them. The coils would rub on the bump tower when i drooped out.
Non-XJ Stuff (2014-2018 Chevy Silverado Stuff) 4xpete SoCal For Sale 3 December 29th, 2019 10:15
stock bilstien rear shocks, dana 30 pinion yoke, other random stuff 8.8 stuff blondejoncherokee Sierra Chapter For Sale 0 September 28th, 2012 23:45
Sprng break/moving sale, Jeep stuff/Other stuff ebxjbob For Sale: Private Party Only. XJ ITEMS ONLY 5 March 8th, 2007 20:13
