Old November 15th, 2020, 09:49
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
steering reservoir leak, oring?
well the stock steering pump is leaking finally (270,000), I cant complain I suppose. It looks to be from where the reservoir mates to the pump. This seems like a a big pia for stopping the leak or getting another o ring/ reservoir/ new pump that wont leak.
I'm thinking of trying that lucas steering stop leak that has some good reviews. Does anyone advise against this, I dont want to muck up the steering system?
If you guys have fixed this what did you do?
Old November 15th, 2020, 21:24
Re: steering reservoir leak, oring?
never mind, I tried Lucas before a long trip today. I followed freeriders thread on this and he tried dang near all other options so ill see what happens.
any moderator feel free to delete this thread.
Old November 16th, 2020, 06:46
Unclewolverine Unclewolverine is offline
They way I got mine to seal was clean up both surfaces real good, re use the old orings and smear the whole mating surface with right stuff gasket maker. I use that crap on everything, its expensive but there isn't a single gasket or oring seal on my xj that leaks a drop!
Old November 16th, 2020, 18:51
Black1990jeep Black1990jeep is offline
it is an easy job to replace the seal, remove the pump, disconnect reservoir, replace seal, put pump back.
do it right, if it fails on you, you loose fluid, your pump fries from lack of fluid, sending metal into gear box, then you got to replace EVERYTHING!
Old November 17th, 2020, 11:12
I'm not intimidated on the job of replacing the seal, Ive just read a lot of issues with this replacement, and/or the replacement of a new unit, still leaking. Ide like nothing more than to simply replace this o ring and have it work, so many folks reporting otherwise had me try the lucas. I think the lucas actually worked because I don't see any fresh drips on the ground. If it starts up again I will pull the pump and try the right stuff suggestion.
Black1990 have you done this fix successfully?
Old November 17th, 2020, 12:09
Anak's Avatar
Anak Anak is offline
Stranger
It has been a couple years since I replaced the O-ring on mine and it has remained leak free since then.
Old November 18th, 2020, 09:29
Yes. Several times I have installed the Oring, never leaked on me. I have gone thru a few pumps, but the Oring replacement went fine every time.
Old November 18th, 2020, 20:18
Well this is great news. I was beginning to think that this might be a lost cause fix.
Thank you for the feed back, Ill get an O ring this weekend.
Old November 18th, 2020, 20:38
remember, the two metal clamps that secure the reservoir to pump are different, they dont interchange, so recall which goes where.
steering reservoir Black1990jeep Modified Tech Discussion 1 October 26th, 2018 15:42
Wtb 00 power steering reservoir H8PVMT NAC Classifieds 6 January 2nd, 2016 15:53
2.5 XJ power steering reservoir leak Overland Modified Tech Discussion 1 April 26th, 2015 21:43
Renix PS pump reservoir leak old_man OEM Tech Discussion 9 October 20th, 2010 10:32
