Old November 11th, 2020, 13:36
Unclewolverine Unclewolverine is offline
Ball joint recommendation
I was trying to figure out the right hand pull and bad wear pattern on my front tires despite pretty much all new steering parts and the alignment measures spot on by tape. Lo and behold, even though they looked new when I bought the jeep last year, the ball joints have play. U joints are shot too, so, awesome. Looks like moog are in it, I was thinking of going with spicer but several reviews say the spicers sometimes fit too loose. Going to be in it that deep im going to do axle seals as well. Probably won't have time or funds to do it until Thanksgiving, just want to know what brand I need to be grabbing.
Old November 11th, 2020, 14:45
Vince's Avatar
Vince Vince is offline
Re: Ball joint recommendation
Moog have been a popular choice when this question has come up before.
Old November 11th, 2020, 15:16
Anak's Avatar
Anak Anak is offline
Stranger
From what I have gleaned over time Moog's quality has not improved over the past few years. It is entirely possible the Moog ball joints you have were indeed new last year and have already gone to pot.
It is also entirely possible that if you now try to put in Spicer ball joints you will indeed find them to be too loose. Not because they are out of tolerance, but because Moog decided to "solve" any problems regarding being too loose by making their ball joints oversized. IOW, you may be stuck with Moog and stuck with replacing them frequently.
Good luck.
Old November 11th, 2020, 16:12
Well I just put in the upper control arm bushing that was almost completely gone and I cleaned up the upper ball joint while I had the wheel off. It is just black with no wording so maybe another brand? Moog will usually have a gold backing plate that says moog problem solver on it right?
Old November 12th, 2020, 07:50
Vince's Avatar
I hadn't realised that Moog had gone downhill. I am fairly certain all of mine are Spicer. I haven't changed any in a long while. The only thing I have been aware of recently was to avoid knurled ones if the plain style are still tight. Thanks for the update.
Old November 12th, 2020, 07:55
Anak's Avatar
Stranger
I have heard conflicting points of view on the subject, but the conclusion that I have drawn is that Moog is probably okay if you stick to pavement, but it does not cut it for anyone who goes off-road. And the knurled ball joints are a one way street. As soon as you start down that path you are committed to it for the life of the axle.
Old November 17th, 2020, 20:02
50willys's Avatar
50willys 50willys is offline
I'm running Teraflex ball joints.
Bob S.
'96 Cherokee, 4.0L w/Auto Trans & locked D44s
Ball joint and U joint replacemet weekend Lake919 OEM Tech Discussion 5 May 27th, 2016 20:34
Ball Joint Press for U-joint work workgoats Tools and Garages 19 February 11th, 2013 06:31
Ball Joint ???'s rmm727 Modified Tech Discussion 9 February 7th, 2008 22:00
HF Ball joint / U-joint tool half off deal... Ivan Non-Tech / Off Topic 7 May 25th, 2005 17:08
Ball joint / axle - u joint replacement rail351 OEM Tech Discussion 7 September 21st, 2003 15:50
