Old November 11th, 2020, 11:34
halmca halmca is offline
'98 XJ 4.0L, 4X4 auto: Length or rear driveshaft
Need to know the length of the rear drive shaft ofabove-described Jeep. Box Stock NON SLE. Preferably as measured between the center of the U-joint loops on both ends. Should be somewhere pretty close to 29.5 inches.
Thanks. In the alternative, if you happen to have one for sale, reasonably priced, and willing to ship it to North Florida on my dime, well, shoot me a PM, please.
Old November 11th, 2020, 15:26
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: '98 XJ 4.0L, 4X4 auto: Length or rear driveshaft
Stock Rear Drive Shaft Length
29 spline 8.25 .... 27 7/8"
1997 + D35 ........ 28 7/8"
1987 D44 .......... 29 5/8"
Drive shaft length measured from the center of each u-joint on the tube part of the drive shaft for 4.0L with AW4 and NP231.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old November 20th, 2020, 07:41
Many Thanks, Tim!
Rear Driveshaft Length wheeling365 Modified Tech Discussion 13 September 2nd, 2011 08:28
Rear Driveshaft Length? DanHfmn OEM Tech Discussion 8 October 19th, 2008 12:09
Length of rear driveshaft falcon556 OEM Tech Discussion 5 March 19th, 2008 18:04
Front driveshaft length between a auto and manual? Close enough to be interchangeable Big Red OEM Tech Discussion 3 July 17th, 2005 06:43
Driveshaft length manual vs. auto xj92 Modified Tech Discussion 3 August 2nd, 2003 20:49
