Old November 17th, 2020, 13:32
David_BNSF David_BNSF is offline
Evap hose issue
On my 99 XJ, I was changing out my Leak Detection pump, at the bottom there’s a 5/8” ID rubber hose that’s comes off of it to connect to a plastic tube that goes behind the block. Well I snapped that tube in two by accident. Not sure what that part is called exactly to get a new one. Any info would be great appreciated. Thanks in advance.
Old November 17th, 2020, 14:00
Ralph77 Ralph77 is offline
Re: Evap hose issue
Guessing here but think you are talking about #8 at the link below?
https://www.moparpartsgiant.com/part...3013043ab.html
If so that is something that you would probably have to get from the boneyard.
Did you just snap the plastic line in one place?
Could just splice in a piece of vacuum hose to repair it.
Radiator hose issue Mrbeemernc OEM Tech Discussion 7 February 3rd, 2017 01:40
EVAP hose replacement CZHipster OEM Tech Discussion 8 June 29th, 2016 20:17
small evap leak and lart evap leak? kdub41 OEM Tech Discussion 2 January 26th, 2010 15:50
Evap Canister Hose Question sflier OEM Tech Discussion 3 December 11th, 2005 21:01
