Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Jeep Picture Showcase
Jeep Picture Showcase Just a place to post (show off) your Jeep or your modifications images.
Old January 17th, 2008, 20:49
Lowrange2's Avatar
Lowrange2 Lowrange2 is offline
Member# 2368
Bead Locks
Thought I'd share. Not sure why but Hey!
I finally finished welding the inner rings in. It took me a while to get the rim in the tire. Then I had to bolt the outer ring on to put some air in them to seat the rear bead. Thats why the outer rings aren't painted and there is only 8 bolts in each one. I've gotta get shorter bolts tomorrow. Those turned out to be a lil too long.
I think I'm gunna paint the outer rings pink.
Should I put washers under the bolts? They're 5/16 bolts.
Old January 17th, 2008, 22:03
Mosephus's Avatar
Mosephus Mosephus is offline
Re: Bead Locks
Looks good, I would put washers under them.
Old January 17th, 2008, 22:47
Jimbo_1321's Avatar
Jimbo_1321 Jimbo_1321 is offline
Re: Bead Locks
what is with you and zac and that gay pink?
Jimbo_1321's Avatar
Re: Bead Locks
oh and btw those rings look sick, wanna make me a set?
Old January 17th, 2008, 22:54
Lowrange2's Avatar
Member# 2368
Re: Bead Locks
I would but I don't have access to the laser any more. Tragic...
Lowrange2's Avatar
Member# 2368
Re: Bead Locks
Lol I was pickin on Zac... it's what I do. I actually think I'll paint them yellow just because I can.
Old January 18th, 2008, 04:38
uncc civilengineer's Avatar
uncc civilengineer uncc civilengineer is offline
Re: Bead Locks
I used 5/16" G5 bolts and Nylocs... but no washers... My cousin's the same way.. They dont have to be tight so I dont see how washers are of any benefit..
Old January 18th, 2008, 06:17
Lowrange2's Avatar
Member# 2368
Re: Bead Locks
Well The holes are just the right size to not use washers but my main reason for wanting to use washers was to put them on the outside so I don't scratch the paint when I thighten them down...because the paint isn't gunna get scratched when I bash them into a rock anyways, right? lol
Old January 18th, 2008, 06:28
Re: Bead Locks
Well I put abot 12 coats of clear on mine and waxed them before the install... helps the bolts grip rocks better..
Old January 18th, 2008, 09:32
Lowrange2's Avatar
Member# 2368
Re: Bead Locks
Sounds like a good strategy. I just got a couple cans of Tractor Enamel. Maybe it'll grip the rocks better...
Old January 18th, 2008, 11:17
SOUTHTEXASXJ's Avatar
SOUTHTEXASXJ SOUTHTEXASXJ is offline
Re: Bead Locks
X2 sick rings I would take a set and yes my semi locs have flat washers under the bolt so I would!
Old January 18th, 2008, 12:15
Re: Bead Locks
semi locs = street locks? If so then yeah I would most definetly put the washer on the real thing since the fake ones have it...
Old January 18th, 2008, 12:47
Re: Bead Locks
sorry mr 4x4 we all cant have the best, to meet you standards!! I want the real thing someday when I am as cool as you!
Old January 18th, 2008, 12:52
Re: Bead Locks
sorry mr 4x4 we all cant have the best avaible to meet you standards!!i want the real thing someday when I am as cool as you!
Funny stuff... I was just messing w/ you.. people get all butt hurt so fast now days.... I mean come on now, were you really seriously recommending them since the street locks have them?
Old January 18th, 2008, 13:02
Re: Bead Locks
no he wont need them but I think they look better with a flat washer if that's something that matter's the looks. And the bolt head wont dig into the plate if that also matters.
Rate This Thread:
BF-G Krawlers and MRT bead locks droldz For Sale: Private Party Only. XJ ITEMS ONLY 3 August 17th, 2006 11:26
bead locks 88flexj Wanted: Private Party Only 5 May 2nd, 2005 15:32
bead locks? xjfrancis NorthWest Chapter 5 November 25th, 2004 22:19
What does everyone with out bead locks air down too? Northern Pride Modified Tech Discussion 19 September 2nd, 2004 19:27
bead locks xjjunkie Modified Tech Discussion 33 June 24th, 2003 10:39
