Old December 20th, 2006, 13:32
xj4life's Avatar
xj4life xj4life is offline
weld-on beadlocks
Anyone have experience with the weld on beadlocks that sit on the outer lip, not the ones that fit down inside. Is it possible to install the rings without cutting the lip? Seems it would be possible, just adds a little width to the rim over the other sytle.
Old December 20th, 2006, 13:49
barillms's Avatar
barillms barillms is offline
Re: weld-on beadlocks
Each wheel has two rings. They both go on the outside normally, but I guess you could do "double" bead lock wheels if you were really ambitious. One ring welds to the outer wheel lip, and other ring bolts to the inner welded ring sandwiching the tire between them.
I don't think the wheel needs to be cut or altered in anyway.
Beadlocks usually don't hold air well over time.
Old December 20th, 2006, 13:57
IntrepidXJ's Avatar
IntrepidXJ IntrepidXJ is offline
NAXJA Member #647
he's talking about the difference in rings that sit inside the lip (on the outside of the wheel) as opposed to the ones that you are supposed to remove the lip and then weld the ring.
as for the question, i've only used the ones that sit down inside the lip of the wheel
Old December 20th, 2006, 14:02
xj4life's Avatar
yupers
Old December 20th, 2006, 14:26
Ramsey's Avatar
Ramsey Ramsey is offline
Mine (except for one) hold air as good as any other wheel.
Old December 20th, 2006, 16:41
DirtyMJ's Avatar
DirtyMJ DirtyMJ is offline
IF you **** them up, yeah, the won't hold air.
But, they should.
Anyways, I saw a set out there that could be welded to the outer lip without removing it. Personally I think I'm going to go with the ones that fit inside the rim as it'll be easier for me to weld in that position (I'm going to stick them...)
Got the beadlocks done. tonesxj Colorado Chapter 8 May 23rd, 2006 06:14
beadlocks Smittty9785 Modified Tech Discussion 5 April 26th, 2006 14:56
Beadlocks and 38.5 SXs BIGWOODY South East Chapter 0 May 25th, 2005 14:31
Beadlocks etaniyani Modified Tech Discussion 12 May 20th, 2004 14:47
Weld on beadlocks and hot girls kissing each other Fore Wheeler Modified Tech Discussion 39 October 18th, 2003 08:54
