Old June 17th, 2003, 18:26
xjjunkie xjjunkie is offline
bead locks
i'm ready to buy rims for my rig. need some input though. should i buy steel rims (american racing, mrt, ect) or aluminum. either way i will weld beadlocks to them. plan on 35's should i get 8 or 10 inch wide. will the aluminum be beadlock be strong enough. plus i'm concerned about weight. for some reason i'm conserned about rotating weight. i read in smokey yunicks bio that for every 1-lb of rotating weight you loose it's worth
10-lbs of standing weight. (yes 10 to 1 ratio, and it was confirmed by numerous chassic experts)
scot
Old June 17th, 2003, 18:58
Jared's Avatar
Jared Jared is offline
I'd go for the aluminum if money doesn't matter. Especially the forged ones, as they are MUCH lighter and stronger.
Any beadlock wheel is pretty darn strong, as they all have big reinforcing ring welded to them.
As far as weight goes, the 10 to 1 thing, accurate or not, is only for acceleration/deceleration. Not such a big deal while crawling.
Tire weight also matters a lot more than wheel weight because they are farther from the centerline of the axle. To demonstrate, imagine 2 sledgehammers connected end to end. Which would be easier to start or stop spinning; with the heads connected together or with the handles connected together? Both combinations weigh the same, but certainly they spin easier with the bulk of the weight distributed closer to the center of the rotation. Same with wheels/tires.
Old June 17th, 2003, 20:03
Goatman's Avatar
Goatman Goatman is offline
There are plenty of companies now who make beadlock wheels, I wouldn't bother trying to make them yourself. Whether you go with steel or aluminum is strictly a matter of personal preference and weight. I can tell you that just from throwing my wheels/tires around while loading, my aluminum beadlocks are lighter than my old steel non-beadlock wheels. I thought about spending the extra money on forged aluminum wheels, but decided that the beadlock rings add enough strength that the price of the forged wheels wasn't justified. Also, if you're leaning towards light weight, the difference in price between the steel and aluminum beadlocks isn't that much.
TEAM/PETTY CASHRacing........2013 Ultra4 Stock Class National Champions
Check out the TEAM Facebook page for the full story of our 2013 winning season: https://www.facebook.com/Team
Thanks to , Falken Tires, Bishop-Buehl Racing Engines, Ten Factory Axles, Brown Dog, Hooker Harness, BILSTEIN, Raceline Wheels, WARN, G&G Auto Repair/Off Road, Yukon Gear and Axle, Full Traction, Cal, Russ, James, and many, many others.
Old June 17th, 2003, 20:15
Mich88XJ's Avatar
Mich88XJ Mich88XJ is offline
I don't know if you are planning on driving on the road or not, but beadlocks are not legal, except for these ones. Just a thought, hope it helps.
Old June 17th, 2003, 20:29
Beezil Beezil is offline
Member #Nay
have you checked out 6x6usa???
I was just looking at them tonight, based on a suggestion someone gave me......
Old June 17th, 2003, 22:02
Cresso Cresso is offline
This topic is covered about once a month on Pirate4x4 , so I won't bother repeating it here. The main gist of it is that a lot of people mention legality when it comes to beadlocks, but no one can produce a written law anywhere that says they're not legal. For what it's worth, there are quite a few people here in Colorado (including myself) running around on beadlocks and I've yet to hear of anyone getting in trouble for them.
Old June 17th, 2003, 22:17
Weasel's Avatar
Weasel Weasel is offline
Champion Beadlocked wheels, or Weld I think they have a real beadlock now.
Forged are the way to go if you want to weld to them. I belive Cast is much more difficult to weld and has some special handling techniques. Even forged wheels should have some heat treating done after being welded to relive the weld area.
Beezil, I talked to someone today that had dealt with the owner (Daniel?) of USA 6x6 and he was saying the guy was just a jerk to him on the phone.
Just add lightness
Old June 17th, 2003, 23:02
Goatman's Avatar
This is getting old. Does anyone know where this urban myth actually came from? Who can show the law that says that beadlocks are illegal? Anyone?
My Champion beadlocks are cast wheels, not forged. Unless you send him you're own wheels, the ones Champion sells are all cast wheels. No way to make a beadlock wheel without welding to the wheel, so I guess you can weld to cast wheels.
Weld does not make a beadlock wheel, only a fake beadlock look wheel.
Old June 17th, 2003, 23:44
JJ13 JJ13 is offline
LOL, how many Police actually know what a beadlock is, and If he/she actually knows what they are, he/she probably wheels and would be drooling over your rig anyway.
Old June 18th, 2003, 00:14
XJguy XJguy is offline
On a Time Out
Fellas its not that are illegal per se, its that they are not DOT approved. The cost of testing is prohibitively expensive for the small companies that manufacture beadlocks.
XJguy
Old June 18th, 2003, 01:13
PhatXJ's Avatar
PhatXJ PhatXJ is offline
I have several cops for friends, and I have gone over this subject with them. They all know what beadlocks are, and they all know that 99% of them are not DOT approved, however, they said that they wouldn't ever pull somone over for just that, unless they used it to get the guy pulled over to check him for something else like we all know cops do and they will admit it. You know, the "your taillight was out 10 minutes ago" thing. Anyway, so they basicly said they've never given a fixit ticket for beadlocks, nor pulled someone over for them specificly. I would, and am getting some for my rig which will be my only set of rims.
Hell, the vast majority of offroad lights, bumpers, rock rails etc are not DOT approved anyway, whats one more thing.
Old June 18th, 2003, 04:59
xj4rocks xj4rocks is offline
Petersen's $wheel and offroard were perpetuating the myth the other month in their beadlock layout. They plain out said they were not legal for the road. Don't know where it started but the mags keep it going.
Xjjunkie: why do you think you need beadlocks? have you rolled one off the rim? i'm running 36's on 8" rims and haven't even really come all that close to rolling one off the bead. the beads are very tight on the rims. just curious. with a 35" tire i would definitely recommend starting with an 8" rim
It seems that beadlocks are the latest bolt on fad that's all. yes they work and yes they're usefull, but my money would be that 80%+ of the people that have beadlocks don't actually need them or don't wheel in spots that would roll beads off the rims.
Old June 18th, 2003, 05:43
Member #Nay
as long as they're no illegal while sitting on a trailer....
(snicker)
Old June 18th, 2003, 05:47
Member #Nay
Weasel, Personally, I'm not afraid of jerks, it just means I hafta be a bigger one!
what would be your top three for beadlocks?
Old June 18th, 2003, 06:02
4ward's Avatar
4ward 4ward is offline
Beadlocks are a necessity to me. The past few times I've been out they would've made a couple of the obstacles I've been trying. I can't drop that couple more pounds I need in order to get my tires to work to their optimum without popping them off the bead. Yes, I've rolled them off on several occasions, and not at the pressures that I'm wanting. If you haven't rolled one off the rim and you're crawlin', most likely you haven't played enough with tire pressures to get it 100% correct.
The acceleration/deceleration issue is a big deal. When you are stuck between a rock and a hard place (pun intended) and you need to romp on the gas to get some momentum to pop over something, that extra little bit will help. I can't wait to get a lighter set of tires and some alloy rims. My junk just can't accelerate out of a hole like it did with my last set of tires/rims.
Walker Evan's Racing has their new beadlocks out that don't have a welded on ring, it's machined in. Ultra expensive and only come in 17's for now though
I have spoked with Daniel on the phone, solicited a bunch of free advice from him. He seems like a stand up guy to me.
Sean
Door locks Dave Buckland OEM Tech Discussion 5 December 10th, 2003 18:54
Blown Bead on trXus: twice none-the-less Jeep'nD Modified Tech Discussion 12 November 27th, 2003 14:21
Narrow rims vs. bead locks Lawn Cher' Modified Tech Discussion 14 September 10th, 2003 18:24
Fake bead locks can be good. Neil Modified Tech Discussion 67 August 26th, 2003 19:14
Electric Door Locks Atom OEM Tech Discussion 2 July 30th, 2003 07:53
