Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Tools and Garages
Tools and Garages This is a place to share about the tools and workspaces used to craft your latest masterpiece.
Thread Tools Rating: Thread Rating: 18 votes, 4.78 average. Display Modes
Old February 20th, 2007, 21:15
RickyN29 RickyN29 is offline
Harbor Freight vs Costco Portable 12v Air Compressor - In Depth Review w/ Pictures
Hey everybody,
I was doing some testing when I realized it would make a great little write up for the boards.
I bought both a Harbor Freight (Central Pneumatic) and a Costco (MasterFlow) and did some in depth testing.
Took too many pictures, but some people love pictures....
So here we go:
Harbor Freight Tools - Central Pneumatic brand High Volume 12v Air Compressor
Item number: 93186
http://www.harborfreight.com/cpi/cta...emnumber=93186
$59.99 online plus shipping
$69.99 in store price
Costco Warehouse - MasterFlow Q-Max High Volume 12v Air Compressor
Item number: 133660
Not Available on Costco.com, in store purchase
$48.99
(No costco? No membership? Contact me for help, I can ship)
Here they are in the package:
Removed from packaging:
Continue to next post
Re: Harbor Freight vs Costco Portable 12v Air Compressor - In Depth Review w/ Pictures
Some notes:
The power cables on the HF unit are substantially beefier. This is important too because as discussed later, these units pull about 30amps under load. Both cables get very warm during operation, I prefer the HF cables. Thicker gauge, and heavier duty clamps:
HF:
Costco:
The Costco unit has a handy little feature, the nozzle acts as a tire deflator. Once screwed on to the valve stem, simply turn and it will deflate the tire, handsfree. Very handy and easy to use. The HF unit does not have this feature
Although not important, I do like that the power switch on the Costco unit is weather/dirt proofed.
Old February 20th, 2007, 21:16
Here are some comparison pictures between the two units:
Noise:
Both units are extremely quiet. They both have rubber feet. (HF Unit has rubber feet attached to metal base, Costco just has rubber feet).
Decibel wise, both units are almost the same. Costco unit has a higher pitch compared to HF unit.
Air intake (filter unit) is easily replaceable on Costco Unit and does a good job of muffling the sound. It is also higher up to avoid sucking in loose dirt/dust from trails.
Storage:
One of the selling points on the Costco unit is it's small footprint and case. The HF unit comes with a very nice hard case, however, as you can see in the photos at the beginning, it takes up substantially more room. The Costco unit comes with a much smaller canvas storage bag which holds all pieces in nice separate compartments.
WD-40 Can for comparison:
Power Consumption:
Both units under full load exhibit and very similar amperage draw (around that rated 30amps:
HF Unit (@ full load):
Costco Unit (@ full load):
At no load, both units drew about 18amps:
Now the most important part!
SPEED!
The Costco unit is substantially faster.
Costco: From 0-40psi on a 31" tire took 3 min 10 seconds
HF: From 0-40psi on a 31" tire took 5 min 30 seconds
An important note: The HF unit runs EXTREMELY HOT. Touching the head of the unit will result in a severe burn. The Costco unit runs warm, but within an acceptable handling temperature.
If you plan to hardwire either of these into your Jeep, make sure to use properly gauged cables as these units draw 30amps continuous. Depending on length of cable, I would recommended 8 gauge +/-.
Costco Unit in Action
Begin:
5 minutes later:
Conclusion:
In my opinion, the Costco unit is the way to go. It is faster, smaller, runs cooler, and comes with a more flexible storage case. Not to mention it is also cheaper in price! The Costco unit claims on the box to fill up a 33" tire in 4 minutes or less. I find that to be a fair estimate.
The HF unit is definitely pretty, but takes up more space, runs too hot, and takes longer. With the excessive heat the HF unit generates, I foresee it wearing out with a lot of use. The case is nice, but too bulky.
I would give the HF unit a 7/10 and the Costco unit a 9/10 (for average users).
Old February 20th, 2007, 21:29
Monkey55 Monkey55 is offline
SWEET!!!! I like your write up.. It's exactly what I was looking for, in a portable air compressor comparison... I was just about to to buy the HF one, but now am going to buy the Costco one based on size, and inflation time..
THANKS.... This saves me a >>>>> in the future...
Elias
Eh-lee-us
Old February 20th, 2007, 22:17
DXJ's Avatar
DXJ DXJ is offline
Great write-up. Does the Costco unit list a duty cycle?
Thanks for all your effort.
Old February 20th, 2007, 22:21
tupton's Avatar
tupton tupton is offline
Great write up!! I just bought the costco unit, but I was also considering the HF, so I am glad I went the right route. I just used mine the other day to bring my tires back up from 20psi to 35psi after a ride. Only took me 8 min total for all 4, and that includes transfer of equipment from tire to tire.
Old February 20th, 2007, 22:28
montanaman's Avatar
montanaman montanaman is offline
Nice writeup!! Thanks for doing that.
You noticed both cables get very warm during operation. If I bought either one of them, I would upgrade the power cables, even if I kept it as a jumper cable connection. Fatter gauge = less power wasted heating the cables and more power devoted to compressing air.
Old February 20th, 2007, 22:34
Ah good question. On the box for the Costco unit, it states "Maximum Continuous Cycle Time: 40 min @ 40psi @ 75 degrees F" !!!! That is pretty darn good if you ask me!
I do not recall the HF one listing anything specific
Old February 20th, 2007, 22:36
Since it won't let me edit, I should also point out that all testing was done at 13.5 VDC (engine running).
Performance is noticeably reduced @ 12VDC
Old February 20th, 2007, 23:06
DXJ's Avatar
DXJ DXJ is offline
Thanks. That looks like a good unit as a spare/back-up/extra redundancy for my CO2 tank. I always like a back-up plan.
Old February 21st, 2007, 08:24
sidewys xj's Avatar
sidewys xj sidewys xj is offline
I have used the cosco one for about two years mine came from cheker auto its the same thing. I hard mounted mine use a 2/1/2 gallon air tank with a 100 psi pressure switch that really helps out with the first tire. for what I paid for it its great I could buy at least 4 of them before I could buy a vair or extreme air so its worth it to me I even bought a spare if mine quit but it has not happend yet. great little compressors.
Old February 21st, 2007, 08:45
davescott davescott is offline
Thanks for the great comparison.
Old February 21st, 2007, 09:56
jdbwrx jdbwrx is offline
I got the Costco unit a few weeks ago (actually got it at Pep Boys) and just finished wiring it up last night. I had a 2 gallon tank from an AC compressor, so I mounted the Tsunami up it. It filled the tank up to 125 psi with out too much trouble. I'll try and get pics later.
Rate This Thread:
OBA from Harbor Freight? tupton Modified Tech Discussion 15 January 21st, 2007 18:27
harbor freight on board air compressor outlander Modified Tech Discussion 42 August 16th, 2006 20:50
Harbor Freight compressor Timber Modified Tech Discussion 2 December 6th, 2005 20:09
Harbor Freight Tools ????? Eagle Non-Tech / Off Topic 22 February 26th, 2004 10:49
