Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Adventure Forum
Adventure Forum A place for outdoor side of your XJ/MJ. Discussions revolve around camping, equipment, and camping trailers. As well as outdoor activities that take off from your XJ/MJ like hiking, geocoaching, and rock climbing. Also the place to discuss tips and hints for the best places to camp off the beaten path.
Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
  #16
Old September 13th, 2013, 22:50
GSequoia's Avatar
GSequoia GSequoia is offline
Everyone says I'm a jerk.
Re: On-board air vs. portable air compressor
I have CO2 and enjoy it.
That said I've got ARBs and an associated compressor and will be plumbing it for additional air one day. CO2 does run out if you don't plan well (or, say, have a leaky valve).
Prior President & Prior SoCal Chapter President
Originally Posted by Bent
Us normal people...
Old September 14th, 2013, 07:07
Ronbo Ronbo is offline
I have C02 and use it for ARBs and tires. Pros: Quiet, simple, high volume and pressure. Cons: Limited supply, expensive to fill - all the shops around here started doing cylinder exchange only, so 10lb tank is about $30.
I'm going to keep the tank for lockers only and mount a Viair for tires.
Old September 16th, 2013, 11:43
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
Highly recommend the 450C. My only complaint is more storage capacity, as I only run a 2 gal tank. I've love to have an aluminum tank built to the dimensions of the storage space under my driver's side rear seat.
My OBA/ARB manual switch setup: http://www.naxja.org/forum/showthrea...=913774&page=6
Speak the Truth-Question with Boldness
Old July 22nd, 2014, 23:19
devildog0's Avatar
devildog0 devildog0 is offline
I'm a big fan of CO2. You don't have to spend the big money on the Powertank kits and whatnot either.
Just a plain ol' 20 lb CO2 tank and a oxy regulator off of Ebay. Less than 150 bucks usually to get the setup. Just make sure it doesn't have a siphon tube in it. You want one without a Siphon tube. It takes a long time to run a 20 lb unit down unless you are airing up a lot of big tires.
Old August 18th, 2014, 15:31
Hillbilly XJ's Avatar
Hillbilly XJ Hillbilly XJ is offline
I use a Viar Portable compressor fast on air ups on 33x12:50's from 17 to 32 psi continuous duty and @170 psi. Really nice kit everything included that you will need.
Rate This Thread:
On board air compressor Grunstad SoCal For Sale 6 April 22nd, 2009 09:46
wtb: portable air/ on board air pyrothugg NAC Classifieds 3 January 1st, 2009 11:20
Harbor Freight vs Costco Portable 12v Air Compressor - In Depth Review w/ Pictures RickyN29 Tools and Garages 96 May 11th, 2008 09:48
a/c compressor for on-board air? fiddleguy Modified Tech Discussion 30 January 23rd, 2005 09:59
