urbexx
- Glendale, AZ
'91 XJ, putting in my rock lights today. Would like to use the factory fog light switch for the lights, but can't find the connectors at the bumper. My XJ is a low optioned model, and didn't come with the fog lights factory. I added the switch in the panel, and the indicator light does illuminate when the switch is on. I also have a fuse for the aux lamps in the underhood fuse box from the factory.
The only unused connector I'm seeing around the front bumper/grille area is a single wire female quick disconnect dropping out under the passenger side headlight area, right by the vacuum canister (WTF is that thing for?). Where would the aux lamp connections be in the main harness?
