Old March 15th, 2007, 23:18
Crawler's Avatar
Crawler Crawler is offline
Condenser to Trans Cooler, Trans Cooler to PS...
Has anybody here with the tow package (or not) used their stock A/C condenser as a trans cooler and their stock trans cooler as a PS cooler?
If A/C no longer works on your rig and/or you can live without it, this seems like an excellent and natural modification opportunity in the making.
If so, I'm very interested in hearing your results to apply here in the desert southwest... ;^]
Old March 15th, 2007, 23:53
sixer's Avatar
sixer sixer is offline
Re: Condenser to Trans Cooler, Trans Cooler to PS...
My AC just kicked the bucket so i was looking at converting it to on board air and now will look at converting the coolers to.
Great idea. have you seen it done or just an idea???
sixer...
JEEP THE PLANET
Old March 16th, 2007, 00:24
Gojeep's Avatar
Gojeep Gojeep is offline
I use the trans cooler as a power steering cooler and have seen the condenser used as a trans cooler too. Might want to keep it running through the radiator cooler so it does not run too cool or put a thermostatically controlled bypass on it.
Old March 16th, 2007, 01:47
Crawler's Avatar
Sixer...
I've heard the condenser to trans cooler idea kicked around before but not the trans cooler to PS cooler. It dawned on me as a "natural" while looking at it the other day. Searched and didn't come up with much of anything.
Gojeep...
Good on ya', mate! I just saw your write-up on the Taurus fan and auxiliary trans cooler. Your mods, workmanship, and write-ups are outstanding. I do have to wonder some about the smaller diameter tubing and the number of passes of the condenser and the resulting effect of static pressure drop.
Old March 16th, 2007, 06:50
Goatman's Avatar
Goatman Goatman is offline
I use a stock trans cooler form another rig for a PS cooler, you use some type of tranny cooler for a PS cooler no matter what you do. The condensor seems too big to use as a trans cooler, though, especially since the XJ isn't a truck towing a big trailer. I'd be concerned that the tranny wouldn't get warm enough much of the time. I'd also want to flush it good before hooking it up to the trans, since if the AC compressor went out there could be metal particles in the condensor.
TEAM/PETTY CASHRacing........2013 Ultra4 Stock Class National Champions
Check out the TEAM Facebook page for the full story of our 2013 winning season: https://www.facebook.com/Team
Thanks to , Falken Tires, Bishop-Buehl Racing Engines, Ten Factory Axles, Brown Dog, Hooker Harness, BILSTEIN, Raceline Wheels, WARN, G&G Auto Repair/Off Road, Yukon Gear and Axle, Full Traction, Cal, Russ, James, and many, many others.
trans cooler 2000xj4x4 Modified Tech Discussion 3 January 15th, 2007 19:40
OEM Trans Cooler Aquit45 OEM Tech Discussion 8 April 14th, 2006 20:53
trans cooler righteyejoe Modified Tech Discussion 0 February 25th, 2006 10:49
Trans. Cooler - What did you do? GSequoia OEM Tech Discussion 10 March 13th, 2005 08:18
Trans cooler CITYBOY OEM Tech Discussion 2 November 2nd, 2004 08:10
