thechief86
- White House, TN
Hey guys, my buddy has a 2002 Wj with the 4.7 that won't shift.
It takes off in third, and stays there, unless you pull the shifter down to 1st, then it's still taking off in 2nd. There is a CEL on, but no engine codes, so I went after Trans codes. I got a P1698, which is no signal from TCM.
I wasn't aware that these had a separate transmission controller other than the main computer for the engine. I know where the ECU is under the hood, and it has been replaced already with no change. I even took the valve body out and replaced the solenoid pack, and the fluid/filters, with no change, and the same code.
Does anybody have any ideas? Any clue where the TCM on that year model is?
2002 Wj
4.7 v8
Automatic
Lifted 4.5" on 33's with jk rubi wheels.
Looks pretty good for a mommy car on steroids, lol.
2002 Wj
4.7 v8
Automatic
