Old October 21st, 2006, 13:05
jeeper01's Avatar
jeeper01 jeeper01 is offline
Exclamation TRANNY COOLER CONNECTOR
changin radiators and dont know how to get the loewer trnny line off of the old radiator?!?!? help!!!
Old October 21st, 2006, 13:09
JJacobs JJacobs is offline
Re: TRANNY COOLER CONNECTOR
It takes a special tool to push into the connector and release all the little holding tabs. Some fuel line tools will work on those.
Old October 21st, 2006, 13:40
jeeper01's Avatar
thanks fpr the prompt reply. we jus decided to cut it right behind the clamp and slide the hose over the new fitting and clamp it down
Old October 21st, 2006, 19:33
Yucca-Man's Avatar
Yucca-Man Yucca-Man is offline
NAXJA Member # 683
Even though you have solved it already, in the event anyone actually searches for this, you don't always need a special tool either. The female portion of the connector under the ears often gets grime underneath it - I actually found a use for WD-40 and use the small tube to wash out the underside of those tabs. Once the underside is clean, press the tabs together (finger or pliers) and pull the line out. The tabs stay with the female portion of the line and come in a quick-install kit from the dealer.
tranny cooler atreyuBLUEXJ Modified Tech Discussion 5 January 26th, 2006 14:53
Turn a Tranny cooler into a Oil cooler? trekfuel80 Modified Tech Discussion 2 May 15th, 2005 16:44
Tranny cooler lobsterdmb OEM Tech Discussion 23 December 19th, 2003 22:05
Replacing tranny line connector with hose clamps 5Cent OEM Tech Discussion 5 October 31st, 2003 06:26
Replacing tranny line connector with hose clamps 5Cent OEM Tech Discussion 3 October 30th, 2003 18:51
