Old March 9th, 2018, 16:22
smokeyyank's Avatar
smokeyyank smokeyyank is offline
XJholic
Hidden winch bumper
Just picked up a winch for the MJ and am going to need to fab up a front bumper. Anyone have a hidden winch design they'd like to share? Winch is a Smittybilt 9.5k. As always appreciate the input.
Old March 9th, 2018, 16:26
Goose_XJ88's Avatar
Goose_XJ88 Goose_XJ88 is offline
Re: Hidden winch bumper
boostwerks
http://www.boostwerksengineering.com...ount_p_14.html
88 XJ Laredo 8" RE SA, drop brackets, 35s D30/44 4.56, AW4, 242, 7100s, Loganís ft winch bumper, JCR swing out tire carrier, JCR sliders, 96 booster, 97+ mirrors & console (FOR SALE)
99 XJ Limited, AW4, 242, Colombia Edition WJ Seats, Stock. Future 4.5" lift, TnT LA, 33s armor, 231 SYE, D30/44 4.56, rear locker, etc
93 XJ 2 Door AX-15 D30/8.25 3.55 swap, (FOR SALE)
92 MJ AW4 2wd, 97 mirrors. Future 4wd swap, 242, MJ 44, Eliminator Roll bar, Bucket seats, 97+ console
Old March 10th, 2018, 08:40
smokeyyank's Avatar
XJholic
I like it, but was looking to fab something. Just trying to see if anyone has and what they did.
Old March 10th, 2018, 09:23
trippled trippled is offline
Did you look at Dutch's bumper? There's a good totm on pirate too that had some good ones
Old March 10th, 2018, 09:25
Anak's Avatar
Anak Anak is offline
Mostly Harmless
Lazyxj has done this.
Here is an album he put together: https://www.flickr.com/photos/lwade/...7604557867782/
There may be more details around here if you search.
Old March 10th, 2018, 19:03
smokeyyank's Avatar
XJholic
Thanks, I did check out Dutch's. I do like his a lot. I'll check out pirate too.
Old March 11th, 2018, 07:28
DutchVDub's Avatar
DutchVDub DutchVDub is offline
You beat me to it lol
Americans can sleep at night because US Soldiers stand ready to fight
Old March 11th, 2018, 13:27
smokeyyank's Avatar
XJholic
Do you have any other pic other than whats in the build thread?
Old March 11th, 2018, 14:25
themauler's Avatar
themauler themauler is offline
I made one. My warn had a removable solenoid pack so I relocated it under the hood.
http://www.naxja.org/forum/showthrea...1104364&page=5
Nick Maul,
Just want to build something that won't break on the trail
Old March 11th, 2018, 19:03
smokeyyank's Avatar
XJholic
Nice, I like the stubby look. Still debating if I want to go stubby or push it out to the edge.
Old March 12th, 2018, 07:18
DutchVDub's Avatar
No, but I could take some.
Old March 12th, 2018, 08:54
smokeyyank's Avatar
XJholic
If you could that would be awesome if not no worries. Just trying to get a better idea of the bracket layout. Did you fab yours or get pre fabbed ones?
Old March 12th, 2018, 14:12
DutchVDub's Avatar
From my thread:
I used Dirtbound tie-in plates and originally had the mounts as part of the main bumper capturing the 3 stock holes and 1 of the steering box bolt holes, then the tube portion had its own mounting plates that captured just the 2 front bumper bolts. This way if the tube part got damaged it was only 4 total bolts to remove it and I could make a new one. I also wanted to be able to remove the main bumper without having to undo the steering box, hence the 4 bolt design. Unfortunately when my buddy bent up the plate for the main bumper (it was all cut out as 1 piece of 3/16 and then bent up) he misread the measurements and the space between the mounts was almost 3/4" too wide. As I was in a hurry to get the Jeep ready for a trip, and not willing to waste that entire piece of plate, I just cut the mounts off of the ends. Being in the hurry I was though I wound up just welding everything together and ended up with 3 layers of 3/16 plate to mount the bumper instead of having either a single side plate that would just be cleaner/more efficient or a multi-piece bumper that would be easier to repair as needed like I had originally intended. If I were to do it again I would stick with the multi-piece design but actually follow through with it. At a minimum I would make it a 2 pieces with the frame tie-in and then just 4 bolts on the bumper itself (tube portion integrated with main bumper). I hate having to unbolt the steering box just to remove/install the bumper.
Old March 12th, 2018, 15:42
smokeyyank's Avatar
XJholic
I see what you are saying. Good idea about the 2 piece.
Old March 22nd, 2018, 21:27
Weasel's Avatar
Weasel Weasel is offline
link to the one I did 10 years ago: https://photos.app.goo.gl/qEpracSz3dOP7uds1
skip all the holes and use 1/4 plate for the lower piece. I had a tubed bumper that slipped over the outer rails and bolt on so 3 total pieces.
Just add lightness
Hidden winch bumper two_door_rob MWC For Sale/Wanted Forum 0 November 28th, 2017 17:26
Hidden winch mount ROKTAXI Modified Tech Discussion 1 June 23rd, 2007 04:43
Warn Hidden Winch Kittrell Modified Tech Discussion 43 July 21st, 2005 15:20
hidden winch? 53guy Modified Tech Discussion 3 April 7th, 2005 19:32
Who's red XJ with hidden winch techno1154 Modified Tech Discussion 18 February 8th, 2005 11:27
