Old March 1st, 2018, 08:54
1995XJ4.0 1995XJ4.0 is offline
Re: Coil spring bow (not your usual case, guarantee you will be stumped)
Originally Posted by ID96XJ View Post
It looks like the coil doesn't fit the isolator how it should.
My thoughts too, but its weird how only one side is like that. Guess its worth $20 and dropping the axle
Sent from my Moto G (5S) Plus using Tapatalk
The upper wrap on the coil appears to be too big around for the OEM rubber isolator.
You might try poly isolators or different coil springs.
Rubicon express so there quality coils, might try a different spacer, or none as a diagnostic? Or bad idea?
Old March 1st, 2018, 08:55
Originally Posted by 1990JEEPXJ View Post
Bent or twisted tube is my bet. You shouldn’t have to use a winch to line the holes up. When I install upper arms I get the proper angles using one upper installed in the cast mount then adjust the other to fit the other mount.
What should i measure to see ahout this though? Ive taken countless measurements and everything checks out! Its driving me nuts.
Old March 1st, 2018, 08:56
Thanks for the replies guys, keep bouncing between coil isolator and bent/spun axle, walk me through some diagnosing, since i could hqve measured undesirable points.
Old March 1st, 2018, 11:38
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
I’d recommend keeping your questions under one username and one thread. You posted the same question a year ago. Maybe a moderator can consolidate them into one
http://www.naxja.org/forum/showthread.php?t=1138295
Old March 1st, 2018, 15:51
Heavyopp Heavyopp is offline
And don't forget the thread thats over in OEM....
Old March 1st, 2018, 21:43
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
A trip to an alignment shop will tell if the caster and camber are correct which will help in diagnosing a bent or twisted tube.
Old March 2nd, 2018, 15:07
anthrax323 anthrax323 is offline
Is the spring seated correctly in the lower perch/bucket? The tail of the spring should sit nicely into a channel, allowing the retainer to be tightened down.
Old March 5th, 2018, 08:57
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
If you look at your lower bump pad relative to your bump tower, it's fairly obvious what's going on. If you don't have a spun or bent axle tube (which should be pretty easy to rule out), your axle isn't centered.
Do you have side pictures of your rig? What about wheel base measurements?
99 XJ Sport Build Thread:
http://www.naxja.org/forum/showthread.php?t=1059015
Check out our website!
www.BoostwerksEngineering.com
Old March 5th, 2018, 10:50
burntkat burntkat is offline
NAXJA Member #1145
Looks like the passenger side tube is spun to me. Put a angle finder on the flat part of the coil seat on each side. Should be obvious in short order.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old March 12th, 2018, 18:49
tonis506 tonis506 is offline
Passenger tube spun, control arm mounts bent or control arm is bent. My money is on the axle tube.
Front Coil Spring ? Should there be a rubber spring isolator? Redsnake OEM Tech Discussion 10 August 12th, 2008 05:17
Weird 231 problem...has stumped all xfer case pros... Road_37 Modified Tech Discussion 12 January 20th, 2006 19:09
Not the usual ZJ coil question! Atl-Atl Modified Tech Discussion 6 July 22nd, 2005 01:54
STUMPED. No start. Tried all the usual suspects. Lucas OEM Tech Discussion 5 June 30th, 2005 17:24
HELP! I've got the T-case apart and I'm stumped. Barger Modified Tech Discussion 3 July 7th, 2003 17:53
