Old March 3rd, 2018, 17:13
RCP Phx RCP Phx is online now
Re: Balance Beads
Yeah 15x10's are not good for 4-wheeling, but what tires are those?
Old March 3rd, 2018, 17:26
burntkat burntkat is offline
NAXJA Member #1145
Re: Balance Beads
Originally Posted by chickenbot View Post
I was by myself and its kind of hard to use a cheetah alone. Also when the lip of the wheel and the bead of the tire are 5" apart
Ratchet strap. Been mounting tires for decades by hand, alone. Never used explosive means.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old March 5th, 2018, 07:24
chickenbot chickenbot is offline
Re: Balance Beads
I've never heard of that method before. I will definitely use that for now on.
Old March 5th, 2018, 07:25
Re: Balance Beads
I am going to do an alignment on it today and see if that helps. I've noticed that side walls are very soft and when they vibrate they do from sided to side instead of up and down
Old March 5th, 2018, 08:40
Heavyopp Heavyopp is offline
Re: Balance Beads
I tried it when doing my 35's on the 10" rims -- still needed the 2nd air blaster
The ratchet strap is a good method for a stubborn bead and not enough air but those 10" wide rims are "special" for sure
Old March 5th, 2018, 08:59
NAXJA Member #1145
Re: Balance Beads
Awesome, glad to help!
BTW, you ARE removing the valve core before seating the bead, right? LOTS more volume that way. And you need a good source of air, lots of capacity. CO2 tank works well too.
Old March 5th, 2018, 09:00
NAXJA Member #1145
Re: Balance Beads
All the more reason to run 8" wide wheels. Better bead retention, too!
Old March 5th, 2018, 09:31
Re: Balance Beads
lol I work at a car dealership and have access to all the "special tools" including a tire machine. And yes I do remove the core
Old March 6th, 2018, 07:22
Re: Balance Beads
So I did my alignment last night and the toe was off -.30. I fixed that and it rides much better. Didn't think little would cause that much.
Old March 6th, 2018, 07:57
Re: Balance Beads
I certainly agree -- I am very hesitant to air those tire down offroad -- The suburban isn't much of an offroad vehicle anyway, here on the east coast, the burb might as well be a school bus in the woods -- it seems to get bigger on the trail
Old March 6th, 2018, 18:31
DutchVDub's Avatar
DutchVDub DutchVDub is offline
Re: Balance Beads
Must be a Yugo dealership if they’re letting you use combustion to set a bead.
Americans can sleep at night because US Soldiers stand ready to fight
Old March 10th, 2018, 18:06
TRCM's Avatar
TRCM TRCM is offline
Re: Balance Beads
Hey, ya know they (yugo) are coming out with a bigger SUV style vehicle this time......it's gonna be called the "weallgo"
Old March 10th, 2018, 18:07
TRCM's Avatar
Re: Balance Beads
sorry double post................
Old March 11th, 2018, 15:41
NAXJA Member #1145
Re: Balance Beads
And on that note..
They also are coming out with a new vehicle for the Millennial generation...
(WAIT for it.....)
It's called the he/she/itgoes.
Old March 13th, 2018, 14:51
Re: Balance Beads
So the beads I have in it now aren't working in the rear so I'm going to try airsoft pellets and more of them. I'm going to try about 14oz in each tire and see how that goes. I'll be using the .2g pellets.
FREE BALANCE BEADS BRIANHO13 Vendor Give Aways 43 March 2nd, 2015 10:02
Balance beads will be back on the site tonight BRIANHO13 Vendor Advertisements 6 February 14th, 2015 16:53
Balance beads BRIANHO13 Vendor Advertisements 0 February 17th, 2014 06:16
Free balance beads BRIANHO13 Vendor Give Aways 75 November 7th, 2013 19:14
Balance tires with ceramic beads? Twisted Copper Modified Tech Discussion 8 February 19th, 2005 06:40
