Old March 2nd, 2018, 08:03
Heavyopp Heavyopp is offline
Re: Balance Beads
Originally Posted by chickenbot View Post
they melted in the tire bead seating process.
Starting fluid?
Old March 2nd, 2018, 08:16
chickenbot chickenbot is offline
Re: Balance Beads
Originally Posted by Heavyopp View Post
Starting fluid?
Brake clean
Old March 2nd, 2018, 08:22
Re: Balance Beads
You installed the beads in their packaging???
http://www.magnumbalance.com/index.php/installation
Old March 2nd, 2018, 13:36
ehall's Avatar
ehall ehall is offline
Re: Balance Beads
I don't like the small pellets for several reasons. If I were to do it at all (which I haven't yet) I would only use the airsoft or metal BBs
my '91 beater rebuild
Old March 2nd, 2018, 15:45
DutchVDub's Avatar
DutchVDub DutchVDub is offline
Re: Balance Beads
https://www.amazon.com/Ukarms-airsof...ds=airsoft+bbs
I used 1 of these 1500 count grenades per tire to balance my 35x12.5r15 KM2's on 15x10 steel beadlocks. Worked great. 1500 .12g BB's comes out to about 6.5oz, just a little less.
Americans can sleep at night because US Soldiers stand ready to fight
Old March 2nd, 2018, 19:28
Re: Balance Beads
Brake clean
Not good for plastic -- hope every drop burns up while seating otherwise you risk soft beads and clumping
Old March 3rd, 2018, 06:00
burntkat burntkat is offline
NAXJA Member #1145
Re: Balance Beads
Also not good for, you know, the tire. Sure it's entertaining, but there are much better, safer, and smarter ways of installing tires.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old March 3rd, 2018, 06:19
fiveniner fiveniner is offline
Re: Balance Beads
Its not a Jeep, but I have used them on my old Ford tow truck with great results. about 10oz per wheel/tire 235/85-16
Used these, only complaint is when replacing tire you get a nice dusting of blsck dust when removing.
https://www.dickssportinggoods.com/p...5000ctsprhvsag
Old March 3rd, 2018, 07:23
Re: Balance Beads
I was by myself and its kind of hard to use a cheetah alone. Also when the lip of the wheel and the bead of the tire are 5" apart
Old March 3rd, 2018, 07:40
RCP Phx RCP Phx is offline
Re: Balance Beads
That sounds like your running the wrong rim/tire size? What did you buy?
Old March 3rd, 2018, 08:22
Re: Balance Beads
I know that pain -- I had to seat 35/12.50/16 General grabber AT2 on to 10" wide rims on my suburban -- the rims are at the top of the recommended size for the tires
Couldn't do it alone, had to use 2 air blasters , firing both at the same time to get the tires to seat -- It was a PIA, they look great, but I'll never go that wide again
Old March 3rd, 2018, 08:54
dan1977p dan1977p is offline
Re: Balance Beads
I'm going to need to get more because in the mornings I get horrible pulsating vibes at 80mph. Last night I opened them back up and put another 1.5oz pre wheel and took out the bags they came in. I thought they were causing the problems b/c they melted in the tire bead seating process.
Yeah, you're supposed to either pour them in free before mounting or remove the valve core and pour them in after mounting. Either way, they need to be out of the bag to work or you'll get vibes.
Old March 3rd, 2018, 12:49
Re: Balance Beads
33X12.5R15 on a 15x10 wheel. It was the wheel size recommended by the manufacture
Old March 3rd, 2018, 12:50
Re: Balance Beads
this is them mounted
Old March 3rd, 2018, 16:09
DutchVDub's Avatar
Re: Balance Beads
15x8's would be better, less likely to lose a bead when aired down. Especially with aluminum wheels.
FREE BALANCE BEADS BRIANHO13 Vendor Give Aways 43 March 2nd, 2015 10:02
Balance beads will be back on the site tonight BRIANHO13 Vendor Advertisements 6 February 14th, 2015 16:53
Balance beads BRIANHO13 Vendor Advertisements 0 February 17th, 2014 06:16
Free balance beads BRIANHO13 Vendor Give Aways 75 November 7th, 2013 19:14
Balance tires with ceramic beads? Twisted Copper Modified Tech Discussion 8 February 19th, 2005 06:40
